fuel pressure numbers- please help
Old Sep 18, 2004 | 02:48 PM
SSTAT's Avatar
I have a miss/hesitation with acceleration, I am about to switch out O2 but figured I better check this. Car has 49K mi. This is what I got-
Ignition on and pump priming = 47
Ignition on and pump finished priming = 38
Running = 37
Running with vacuum off of regulator (?=WOT) = 47
Engine turned off = 29
With the ignition on and the pump stopped priming is it supposed to drop 10psi like that? Even so it looks like it has good pressure with WOT so I'm not sure if it explains my problem anyway. I want to check with you guys before I put $200 worth of sensors in. thanks-
Old Sep 18, 2004 | 02:52 PM
'94 Bad A Z28's Avatar
Re: fuel pressure numbers- please help
Everything looks normal to me.
Old Sep 18, 2004 | 02:58 PM
SSTAT's Avatar
BTW, when I first hooked up the pressure gauge (engine had been off about 12 hrs) and tried to bleed the gas nothing came out (no pressure), had to turn the ignition on and off a few times to bleed the air out, is this normal?
Thanks-
Old Sep 18, 2004 | 03:15 PM
Thanks-
Probably more normal than abnormal. I would not worry about that.
Old Sep 19, 2004 | 02:11 PM
SSTAT's Avatar
Thanks for the help guys-
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
