lt4 standard cam question
Old Sep 16, 2004 | 06:36 PM
Formula305fi's Avatar
Exclamation lt4 standard cam question
the lift on the lt4 standard cam is .476/.479 is that @ 1.6:1, or 1.5:1.. I have my engine opti out and intake manifold off along with rockers (during 1.7 conversion) my friend will give me a lt4 standard cam for free.. just wondering if thats the lift with 1.5, if not then if its the 1.6 lift max lift with 1.7s would be around .505/.510 which would be in the perfect flow range for the stock heads which flow peak around there.... thus i should make decent power and nice torque.
Old Sep 16, 2004 | 06:45 PM
RamAir95TA's Avatar
Re: lt4 standard cam question
Those numbers are with 1.6 rockers, since production LT4 engines came with 1.6 rockers, not 1.5s. Specs for the production LT4 cam:
I203/E210 I.476"/E.479" 115LS.
Old Sep 16, 2004 | 06:50 PM
cool so it will be right in the prime flow area of those heads
Old Sep 16, 2004 | 06:52 PM
RamAir95TA's Avatar
You may have misunderstood. The .476"/.479" numbers are WITH 1.6 rockers. Not the .505"/.510" like you had hoped...
Old Sep 16, 2004 | 06:54 PM
yes it will be .505/.508.... i divided by 1.6 then multi by 1.7 got the numbers... i know what u ment it being 1.6 #s the 1.5 # are like .44x. should also put out a lil more power and torque...
Old Sep 16, 2004 | 06:55 PM
RamAir95TA's Avatar
Ah...then I read wrong. I didn't see that you had intended on using 1.7 rockers. Kudos.
Old Sep 16, 2004 | 06:57 PM
Yeppers. going for the sleeper thing, plus its free so why not use it ya know what harm can it do... i doubt i will lose power with it... im hoping for 315hp/340ish tq.
Old Sep 16, 2004 | 07:58 PM
96capricemgr's Avatar
Honestly I put a ZZ3 cam in my Caprice and it is asumed stock by everyone I do not specifically tell it is changed, and that is bigger than the production LT4 cam, after doing the swap and driving it for a year I would say that even in a b-body which comes with a smaller than f-body cam the ZZ3 is the absolute smallest cam worth the effort. Even if LT4 cam is free I would recommend a ZZ3 or 227(210/224 crane) both will make more power than the LT4 and are still mistakable for stock. The 227 has made some wickedly fast cars too both b and f-body.
Old Sep 16, 2004 | 08:02 PM
where can i get a zz3 cam, and what are the specs on it... i got a 224/236 i bought but i dont wanna use it so im not going to. Also is the zz3 the same as the zz4 because my friend had a zz4 cam in his hsr motor and that thing loped... im not looking for a lopey idle thats why im not using the xe224/236.
Old Sep 16, 2004 | 08:37 PM
The ZZ3 cam is a readily available GM performance parts piece pn 10185071 , think gmpartsdirect(good for looking stuff up not for buying) lists it at $165 and it needs a small amount of machining($20) so the opti fits right. Specs are 208/214 .474/.510 with 1.5s on a 112. Thing is so well mannered that I used to tow a small boat with it backed by a 1650 stall and 2.93s outback also keep in mind my car is about 4200 without me. Even then it was stock mannered till I get on it then it pulls more in the midrange and to a higher rpm than the stock cam did. I do plan on swapping it out but not till winter. If you want I could posted a wanted for you on the b-body board, obviously a mild cam like this is more popular over there. Desktop Dyno says about 360/360 for this thing if the rest of the car is in order you know good intake and exhaust, I would guess your SLPs are shorties so I don't see you getting the full 360 but you get the idea.
I am running a very basic intake(involves 3" pvc and cutting a hole in the airfilter box) with the stock small b-body MAF, stock exhaust manifolds, 87 octane mailorder tuning and have a heavy drivetrain and still put down 260 to the tires, which should be 320 or so flywheel. You have better intake and exhaust and a lighter drivetrain so your results will be better.
Old Sep 17, 2004 | 11:21 AM
LT4Firehawk's Avatar
Don't bother with the stock LT4 cam, it won't be worth it and you will probably see ZERO gains.
Stock LT1: 205/207 477I/490E w/1.6
Stock LT4: 203/210 476I/479E w/1.6
LT4Hotcam: 218/228 525I/525E w/1.6
If you are going to go through the effort of doing a cam, at the very least I'd go with a Hotcam.
Old Oct 18, 2004 | 10:18 PM
well i have a crane 2031 i could machine to work in my lt1. its specs are 208/214 112lsa .438/.452 @1.5rr. I got 1.7rrs i would use but u get the idea... worth putting the cam in?
LeftoverChinese
Jan 14, 2024 03:03 PM
95chwagon
Jan 13, 2015 09:19 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
