awesome... car was pulling serious degrees timing
Old Nov 14, 2003 | 02:47 PM
ZDriver96's Avatar
Well at track day she did 106.5 or so in the traps and putting around 330rwhp to the ground (318rwhp before long tubes, Gained 2 mph in 1/4, approximating 12rwhp increase).....
well...
tuner cat showed the computer pulling 40 degrees of timing...
40 freaking degrees.....
That fixed with my new mods..... I cant comprehend that gain...
should the car been trapping 111mph with no timing pulled?
cant wait to see what the heads,cam,
Old Nov 14, 2003 | 02:55 PM
Are you saying you had 40deg of knock retard, or were you simply reading the programmed advance, which is often shown with a negative sign in front of it.... e.g. "-40deg"?
Old Nov 14, 2003 | 02:56 PM
madwolf's Avatar
You're looking at the wrong table.
Stock, maximum knock retard is 15 degrees. Usually 12 though.
You need to datalog the car, not look at the program with tunercat.
Old Nov 14, 2003 | 03:07 PM
ZDriver96's Avatar
hold up.. i'll try to post the log for it..
Bob the guy tuning my car said it was trying to pull 40 degrees... maybe it was only pulling 15?
He's going to send the log.
blac94Z
Dec 2, 2014 12:09 PM
owen66
Nov 30, 2014 04:21 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
