CC306 Smog??
Old Nov 14, 2003 | 01:46 PM
SVT Killer LV's Avatar
CC306 Smog??
So right now I have a 306, blah blah blah, with 1.6 rockers. Now do you guys think if I got a set of 1.5rr's (to knock lift back down to 510/540) and put a lean lean lean smog tune on it, Do you guys think it will pass, even with those duration numbers?
Old Nov 14, 2003 | 02:16 PM
Brandon 95 Z28's Avatar
I dont think the lift will help you pass much. Its mainly the duration and LSA. I think you will pass with a GOOD emissions tune and a stock-like cat, and maybe the right alcohol mixture.
Good Luck!
Brandon
Old Jul 20, 2004 | 02:16 PM
djlup's Avatar
Re: CC306 Smog??
Any luck with the smog test?
I also have a CC306, that will need to be smogged soon.
Old Jul 20, 2004 | 03:27 PM
SS MPSTR's Avatar
Re: CC306 Smog??
Hate to be the Doubting Thomas here, but I don't think that cam will pass at all. The thing has just got too much overlap.
Old Jul 20, 2004 | 03:29 PM
truedualws6's Avatar
Re: CC306 Smog??
I say won't pass.
Not to be negative, but I have read a lot of posts on this topic and have yet
to see anyone pass CA smog with a 306.
Old Jul 20, 2004 | 04:48 PM
neil350's Avatar
Re: CC306 Smog??
Its been done, but your better off looking for a "friendly" in$pection place.
Old Jul 20, 2004 | 10:48 PM
LT1 Bunny's Avatar
Re: CC306 Smog??
why not just a double cam swap?
Old Jul 20, 2004 | 11:36 PM
Kain's Avatar
Re: CC306 Smog??
I passed no problems with stock heads. Although I've got a cat after each collector.
Old Jul 21, 2004 | 03:59 AM
djlup's Avatar
Re: CC306 Smog??
Just dual cats?! No smog tune, hot sparkplugs, pushing air in before the cat, or running a special fuel mixture? Sounds to good to be true, but I want to believe it.
Old Jul 21, 2004 | 01:27 PM
sherwinZ28's Avatar
Re: CC306 Smog??
I was planning on using one of these:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33629
Just weld it onto the exhaust system after my two stock cats and connect a hose from a small air compressor to the inlet of the cat to add extra air. I already have a small air compressor that can fit in the truck and run a hose to the cats inlet pipe...you can see it in the pic. Any comments on this? I was also going to tune it once I get the software.
Old Jul 21, 2004 | 01:52 PM
944v8inDFW's Avatar
Re: CC306 Smog??
Keep us posted on the CC306 and smog. Not that i care but i am intrested in case i sell the car.
Old Jul 21, 2004 | 03:29 PM
djlup's Avatar
Re: CC306 Smog??
I don't think that's an inlet pipe, but a hanger.
Old Jul 21, 2004 | 03:55 PM
sherwinZ28's Avatar
Re: CC306 Smog??
Not sure if your talking about my post but I have the cat sitting in my room and the tube has a hole in it that seems to go into the middle of the cat. The seller also stated it was an air inlet tube. That was the only reason I bought it...that way I wouldn't have to drill holes into my stock cats.
Old Jul 21, 2004 | 07:13 PM
LT1 Bunny's Avatar
Question Re: CC306 Smog??
What did your car blow when you did this? Hmmm, screw double cam swaps...you could just piggie back 2 cats in a row behid both collectors.
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
