Will the valves hit the pistons?
Old Nov 12, 2003 | 05:39 PM
Rodrigues's Avatar
Im curious if the valves will hit the pistons with this cam I have in the car using 1.6 rockers
230/236 cam 112 lsa with 4 degrees of advance ground in (108 ICL). The lift with 1.6 rockers will be .622/.624. The lift with 1.5 rockers would be .583/.586.
I already have 1.6 rockers but im curious if I have to go down to 1.5 rockers. My heads flow numbers increase and a constant rate up to .7...
I have CM618 springs from my last 224/230 cam but I am not sure if I will be able to use these or not, I would obviously have to get 1.5 rockers if I did. I also have stock lifters, will this cam just be too much for them? What springs would you recommend and what rockers would be best?
Old Nov 12, 2003 | 05:49 PM
got_hp?'s Avatar
get new lifters
call combo and find out how much lift those springs can handle
Old Nov 12, 2003 | 08:12 PM
kmook's Avatar
Advanced Tech Moderator
People can only make educated Guesses on if setup X or setup Y is going to have piston to valve contact or not.
Only way to make sure is check physically before you start up the car for the first time.
Anywho, this should be discussed in LT1 Tech. Moving-Thanks.
Old Nov 12, 2003 | 08:45 PM
dnz28's Avatar
your springs wount handle that big there only good to .600"
Old Nov 12, 2003 | 08:58 PM
Rodrigues's Avatar
going by the information from this thread http://web.camaross.com/forums/showt...hreadid=118958
I dont think I will have piston problems.
Are there any springs that would drop in and allow me to not take the heads off to replace the old springs with ones that can handle aprox .650?
bradpreece95z28's Avatar
The only way for you to know for SURE is to test it yourself....
I recommend the play-doh method
Old Nov 12, 2003 | 09:41 PM
kmook's Avatar
I wouldnt go off of that thread, i dont know where HungryT/A got his number of .650 lift and below is fine but there is no spacific lift number since duration plays a big role in PTV clearnace also.
Old Nov 12, 2003 | 10:18 PM
Ai's Avatar
Ai
Always check piston to valve clearance if you don't know it'll safely clear (and how do you safely know most of the time... by checking ).
Regarding those lobes.. those are the 3100 series XE lobes, correct? I'd consider running a 1.5RR and a spring like the cc985, or something like the 977's with 1.6's. Either way, I'd replace the springs - it's cheap insurance. Those lobes are great, but alot of people run into dynamic problems with flimsy valvetrain parts & really aggressive stuff like that. Good luck
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
