Best header gasket w/ hooks on the end???
Old Nov 13, 2003 | 09:23 PM
96 WS6's Avatar
Just like the subject says. These Felpro 1406's are not working out for me I need some metal gaskets. However, I need some with hooked ends so I don't have to remove the header completely because it was a major PITA to get them lined up and would be even worse with a header gasket to hold in place too.
Thanks.
Old Nov 13, 2003 | 09:45 PM
Z95m6's Avatar
I would recommend Percy's Deadsoft Aluminum header gaskets. They are reusable and will never blow out. They are like 40 bucks though. I think you will have to pull the header loose to scrape all the old gasket off the head.
Old Nov 13, 2003 | 10:15 PM
96 WS6's Avatar
There is no old gasket material the gasket comes out leaving no traces... maybe because I used RTV on both sides. Those Percy's look like they will seal up nicely. Did you use RTV or just stick em in how they are???
Old Nov 14, 2003 | 06:25 AM
97FormulaWS-6's Avatar
well, the BEST header gaskets don't have the hooks, but they are the BEST at sealing and torquing...
Earl's aluminum, with the graphite composite inserts... maybe by Parker-Hannifin (THE SEAL COMPANY)
Old Nov 14, 2003 | 06:42 AM
96 WS6's Avatar
I tried those and could not get them to line up and put the bolt in. The fit was ****ty too and I had to cut them because they were not D-port anyway. So far it seems as if I'm going to have to get Percy's...
Z28tech's Avatar
Copper From Summit
I put the Copper gaskets from Summit on my headers, and have removed the headers twice since then, and the gasket is still good after 6 months and two remove and replace episodes. I urge you to tighten your headers once a month for first 3 months as I lost on of my header bolts being complacent and not checking. Also use quality gaskets at the header collectors too. My Car ran like crap with a leaky collector gasket. It was a $1:50 mr.Gasket paper from Auto Zone, and it turned to shreds and blew out in short order.
Old Nov 16, 2003 | 12:24 AM
revtime's Avatar
Mr Gasket copperseals.
Put em in with the LT install and no problems since.
Old Nov 16, 2003 | 03:25 AM
madwolf's Avatar
I used Percy's gaskets. They are really nice and went it without any problems. Now as far as sealing goes, I have no idea yet since I haven't started the car. I'll let you know very soon.
Old Nov 16, 2003 | 03:32 AM
96 WS6's Avatar
Sup Ion. I was just in my "office" finishing up the valvetrain on my install. Let me know how those gaskets worked out! Oh and I ended up getting real Comp R lifters with the CC875 printed on them Score!
Old Nov 16, 2003 | 04:59 AM
97WS6SCharged's Avatar
I used a set of the Mr. Gasket copper gaskets. Have you tried those new locking header bolts? Not the stage 8 bolts with the clips, those fall off. These new bolts have a small hex screw that you tighten to spread the bolt inside the hole kinda like the poly lock rocker nuts. They lock and don't back out. I'll find out exactly who makes them and post a reply, but I'm going to get a set when I have a spare $60 dollars. Definately getting a set for my TT GTA when it's ready.
Old Nov 16, 2003 | 05:02 AM
96 WS6's Avatar
Wow they make header bolts like that!!! Please inform me!! I'm using those stupid Stage 8's... They are way too short IMO and I don't even use the locks as it would take way too long to get them on. I'm always checking to make sure all the bolts are torqued and it's a PITA. I'd definitely be interested in a set of thsoe...
Old Nov 16, 2003 | 05:16 AM
anaik's Avatar
Talking about these?
http://www.go-breslin.com/Splitlock.html
Old Nov 16, 2003 | 05:32 AM
That's them, your link didn't work, but here's one that worked for me.
http://www.ecklers.com/product.asp?d...N9J7HVRHN5BVS6
As I said, they aren't cheap, but they sure do work. I think I'll pick up some this next week when I make another payment on my stroker package.
Old Nov 16, 2003 | 07:50 AM
JohnOConghaile's Avatar
All the dead soft ones are great. if you arent going to be pulling your headers often they are kinda spendy. I went with good ol' felpros with ultra copper and stage 8 bolts and have never never never had a leak.
Old Nov 16, 2003 | 08:05 AM
magius231's Avatar
honestly, I haven't had any problems whatsoever with my fel-pro 1406's. If yours are blowing out, you have one of two problems: 1. your sealing surfaces aren't straight (heads or headers) or 2. you didn't retighten the fasteners consistantly. When I installed mine, I went for a 10 minute drive, retightened the bolts. Drove for 2 hours, retightened the bolts. I then checked them every day until they stopped loosening, then once a week for about 2 months. Its a pain, but I haven't had to mess with it since, and I have yet to blow out the original gaskets in there. I still check the bolts every month or so for piece of mind, but they don't loosen anymore.
