Code Trouble
Old Nov 14, 2003 | 03:21 PM
biddybird21's Avatar
Code Trouble
Does anyone know what code "16" means????
when just running with the simple "service engine soon" way.....
that's the code i meant to ask about earlier..not 12
I got a 93bird...........
Old Nov 16, 2003 | 10:39 AM
DTC 16 = loss of low resolution pulse signal from the OptiSpark. If your engine is actually running, that is just a "stored" code. If it was an "active" code, the engine wouldn't be running, because the ECM shuts down the fuel system (pump and injectors) on loss of the low res signal.
It isn't unusual to see this as a "stored" code. Clear it (pull ECM BAT fuse for 30 seconds) and see how soon it comes back. If it is always there, could be signs of a problem with the Opti.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
warmeck
Feb 2, 2015 12:44 AM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
