Lt1 vs. Ls1
Old Nov 12, 2003 | 09:28 PM
nat's Avatar
nat
Lt1 vs. Ls1
Is one of these engines easier to work on than the other? i.e. routine maintenence and mods.
Old Nov 12, 2003 | 09:33 PM
WrecklessZ's Avatar
Do a SEARCH I'm sure there are tons of Threads
Old Nov 12, 2003 | 09:36 PM
matts_z28's Avatar
I bought my car from my friend who is a Chevrolet mechanic. He says the LT1 is much easier to work with. He port and polished my heads and did a 5 angle valve job on it. I know it's not the fastest Z but I have not lost to a LS1 as of yet.
Old Nov 12, 2003 | 09:39 PM
jasons93z's Avatar
for the millionth time, but i would definatly vote for the lt1
Old Nov 12, 2003 | 09:54 PM
RickS's Avatar
well considering your on the lt1 board....
the lt1's are from a little older year, making insurance that much less to deal with., u can get an lt1 to be pretty damn quick.
i think lt1 blocks are stronger., so that means they can take more than the aluminum blocks right?
Old Nov 12, 2003 | 10:00 PM
matts_z28's Avatar
I heard the same thing about the blocks. Stronger!
Old Nov 12, 2003 | 10:12 PM
Ai's Avatar
Ai
$ not being an issue, you're shorting yourself if you start with an LTx series engine - that's obvious.
What else is obvious however.. is that $ is always an issue . FWIW, I don't think you'll be at a great disadvantage with an LT1 car considering the $ saved... though I've seen some LS1 rides going at some attractive prices lately.
IMO, it comes down to figuring out a realistic budget & adhering to it
Regarding block strength, I don't think that's an issue for most people either way .
Old Nov 12, 2003 | 10:17 PM
got_hp?'s Avatar
ls1 is simply head and shoulders above the lt1.
theres not contest at all.
i wish they had been cheaper when i was car shopping.
Old Nov 12, 2003 | 10:19 PM
RickS's Avatar
well if u get a 93-97 series the insurance would be less than the 98-02 cars, saving you some more "money cash"
but yea the ls1's are faster from the factory.
Old Nov 12, 2003 | 10:26 PM
fredmr39's Avatar
Re: Lt1 vs. Ls1
he didnt ask for the fastest or most affordable engine....just what was "easier to work on"
Old Nov 12, 2003 | 10:28 PM
S.J.S.'s Avatar
While building my stroker...my machinist told me that the Lt-1 is easier to work on and BUILD. He also told me that its harder to stroke or bore (I'm not sure ) but something about the cylinder sleeves being too thin.
Old Nov 12, 2003 | 11:34 PM
mr_muff's Avatar
the ls1 is quite a bit eeasier to work on, like plug changes and stuff. quite a bit more room. the ls1 is more expensive but it is a better engine than the lt1. lighter, more hp, better gas mileage, and no real difference in stregth. how can you go wrong
to the guy that said he has never lost to an ls1: i hope you have more than just a port and polish and valve job, if not you must have some really really bad drivers where you are from. most ls1's put more than 300hp down to the wheels or more bone stock. go to the ls1 section and look at some dyno sheets.
going to have to pull the good ole flag out unless you have more done.
you lt1 guys need to wake up and look around. how can you tell him the lt1 is a better engine?
Old Nov 12, 2003 | 11:39 PM
Heatmaker's Avatar
Advanced Member
LS-1 hands down.
Old Nov 12, 2003 | 11:42 PM
SS Mark's Avatar
to the guy that said he has never lost to an ls1: i hope you have more than just a port and polish and valve job, if not you must have some really really bad drivers where you are from. most ls1's put more than 300hp down to the wheels or more bone stock. going to have to pull the good ole flag out unless you have more done.
LS1 yes is a better engine, but the block on the LT1 is much stronger, cmon, iron vs aluminum, its common sense
LT1 is not a bad engine, the LS1 is just better designed, its mainly because of the head design.
Old Nov 12, 2003 | 11:47 PM
93formula's Avatar
we can fit 18* heads on our block as well. some machining required
