gear question
Old Nov 13, 2003 | 03:39 PM
red_warrior_z28's Avatar
gear question
would driving on either 3.42's or 3.73's for long periods of time (about 250 miles nonstop) hurt my car. if so in what ways. would it also affect my speedometer. even with the HPP3
Old Nov 13, 2003 | 03:57 PM
You lost me on that one... stock LT1 M6's run forever on 3.42's. Numerous people run 3.73's and 4.10's. Why do you feel it would be a problem on your car? If you have an HPP, you can correct the speedo. Are you switching from 2.73's, and perhaps concerned about shift point issues without correcting for the higher numerical gears?
bandit1's Avatar
Gears are going to effect 2 things: gas mileage and performance. Changing gears and not upsating the PCM would effect your car. Getting gears and using Hyperjunk to update the PCM will make things A-ok.
Later,
Mike
Old Nov 13, 2003 | 04:04 PM
Tair's Avatar
yep, won't hurt your car
Old Nov 13, 2003 | 04:26 PM
forgot to mention its an A4, and also will it hurt it after time (meaning doing 250miles every other weekend)
Old Nov 13, 2003 | 04:34 PM
i thought that because the rpm's would be higher driving at around 80 or so it would affect my engine or tranny after sometime. what rpms will i probably be at driving 70- 90.
Old Nov 13, 2003 | 04:37 PM
bandit1's Avatar
3.73's will cause you to run at a higher RPM while at crusing speeds; thus knocking a few MPG off your car. Other then that it's all good.
Later,
Mike
Old Nov 13, 2003 | 05:03 PM
Dave89IROC's Avatar
my third gen has 3:73's and an A4, at 80, the RPM is 2700-2800, this is also dependant on tire size, I am running 255/45/16
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
