Can I use these Injectors ?
Old Nov 14, 2003 | 03:33 AM
Van5150's Avatar
http://www.jegs.com/cgi-bin/ncommerc...31&prmenbr=361
Unless of course someone knows a better injector/price somewhere else.
Old Nov 14, 2003 | 04:23 AM
97WS6SCharged's Avatar
I'm going to assume that you're planning to use the 30 lb/hr injectors. Yes, these motorsport injectors will work in your LT1/LS1/L98 or a ford EFI product. I would also invest in an adjustable fuel pressure regulator. These injectors seem to work pretty good for mild upgrades (bolt ons/heads/cam). For nitrous or a blower I would go with a set of flow tested injectors. Good luck.
Old Nov 14, 2003 | 05:36 AM
slopokrodrigez's Avatar
Why? Is there something wrong with the stock ones? Go here first.
https://www.camaroz28.com/calcs/index.shtml
Look at the 5th up from the bottom, then decide if you need them.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
