sputter around 4000rpm
Old Nov 12, 2003 | 06:12 PM
RickS's Avatar
Angry sputter around 4000rpm
i am having a sputter around 4000rpm,
it was happening allot worse before, i ran a 15.1 in the quarter, but since then i got new wires, and it fixed most of the problem, gettin me a 14.20 , it still has a sputter i cant figure it out, also the gas mileage sucks 13.5mpg, around town driving. i was wondering if it could be a bad/dirty injector.
could i clean the injector? what should i do? there is no service engine soon light.
what u all think i should do/check
Old Nov 13, 2003 | 01:28 PM
RickS's Avatar
ttt
anyone have similar problem?
Old Nov 13, 2003 | 02:30 PM
Black_Z28's Avatar
It could be a fuel filter. Try replacing that. I have a problem with my fuel pump, but there was a pretty drastic change in acceleration.
Old Nov 13, 2003 | 02:34 PM
94GrayV6's Avatar
How are the plugs? There are MANY things that could cause your symptoms. Get some logs of the car.
Old Nov 13, 2003 | 03:17 PM
RickS's Avatar
when i first started having the problem i changed the fuel filter, it didnt help at all, so i put new plugwires in it. fixed 70% of the problem, i went and put new tr55 plugs in her, and still sputters in the upper rpm range. i dont know if its me but it seems like when its hotter it sputters more. sometimes if i floor it it will rev up to like 4000rpm and act as tho its hitting a rev limiter or something, but sometimes it will be somewhat smooth.
thanks for the replies
my car is a 95 lt1 with 91000 miles
ive had it for a couple months, i cnanged the oil twice. i take care of her as best i can
Old Nov 13, 2003 | 03:24 PM
Droff's Avatar
I noticed mine doing this lately. I only noticed it after I put the cutout on. When I close it I can’t tell as bad. It does it the most in second gear with light load or WOT in second. It is kind of strange. I was kind of hoping it was a rich need to retune thing. I does run rich! I am going to check the wires in the dark to see if there is any arcing.
Old Nov 13, 2003 | 06:32 PM
94GrayV6's Avatar
Did you change the coil wire too? Many high rpm hesitations are cured by changing it. Also, try checking the coil. There is a description of how to do it here.
Old Nov 13, 2003 | 06:37 PM
RickS's Avatar
i thought i would try seafoam,
i went to napa and bought some seafoam, well it must not be my day cuz i had the can sitting in my engine bay, and i went inside to grab my squeeze bottle for it, and when i came out the wind had blown the hood down crushing my seafoam. it splatered everywhere, i washed the front body , and used a towel to soak up most of the other stuff.
can seafoam damage my clear coat?
i was freezin my *** off. i did get it cleaned up tho,
tomarrow il get a new can and be extra careful
also, does anyone know where i can get seafoam besides napa?
is it normally $7.81 ish?
Old Nov 13, 2003 | 06:59 PM
Cmr0z28's Avatar
In this case I'd go straight for the opti. Droff - sounds like you're getting knock retard. Get an LT4 knock module.
Old Nov 18, 2003 | 09:14 PM
RickS's Avatar
i used some seafoam its runnin real clear now, i took her to the track she rad a 14.0 flat with missin 5th gear at the last 200feet
before was 14.2
i think the problem was solved
thanks for the replys i apreciate it
update 12/01/03
i just installed the lt4 knock module it eliminated the idle shaking thing, i havent gotten a sputter. looks like the case is solved.
Thanks for the tips
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
