16X8 tire size question?
Originally posted by SS Mark
225/50/16 will fit fine, just about any 16" tire will fit on there, it may look a little wierd if you go to skinny though, Why do you want a 225/50 on there?
Originally posted by ShelbyZ28
The speedo will be off quite a bit with a 225/50 tire. With a 225/55 its less than a 1% difference vs the stock 245/50.
My point was why go with a 225 at all? unless they are snow tires
. But hopefully I won't get stuck with them. I hate snow
i found new 225/50/16 and wonderin if they would fit. i could get them for free!! my back tires would be the ones to replace and im guessing they would look stupid with 245/50/16. i dont want to buy tires for winter cause im gettin a beater 4x4 or something.
winter driving
if you plan on buying these tires for snow, then discount tire is running a sale till the end of this month.
the firestone bliztrac tire mounted & balance $118.00 each.
225/50/16
i dis agree with the speedo being off, as long as you maintain your wheel height from the factory tires, your speedo should be fine.
tony
225/50/16
tony
Re: winter driving
tony
tony
To answer his question yes a 225/50/16 tires will fit but they speedo will be 3.1% off.
Bryan
Re: Re: winter driving
The 225/50/16 will cause the speedo to be off 3.1%. So if you were going 60 MPH your speedo would say 58MPH. Not to horrible but as you speed up it gets worse. I wouldn't want to drive with it off that much. A 225/55/16 will only be 0.4% off.
Bryan
Bryan
thats why when you buy tires, for these cars you make sure you
get the same tire od.
Re: Re: Re: winter driving
how is it possible if you keep the same wheel dia?
http://www.miata.net/garage/tirecalc.html
Bryan
Poor bastards. I'm glad I don't have to deal with snow!
