time for bigger cam
time for bigger cam
well guys it is time for me to get a little serious with my car,i love my hot cam but i want to get my heads ported by loyd elliot what is a good cam to go along with his heads? i would love to hit 400rwhp.the car is driven on the street and has and will see the track.it is a 1994 6 speed with all the bolt ons in my sig. please give me some suggestions i want to do this right and i need some experts advice
thank you in advance brian
A custom grind matched to the heads would be a good choice. The bigger cams (gm 847. cc306. xe230/236) are the ones that will get you to there. I would also consider advanced induction heads. There are a few guys throwing down big numbers with them. The tune is going to be key.
I have Lloyd's heads and made the numbers in the sig with a 230/236-112 cam. I chose a bit smaller cam than the Comp 306 or GM 847 to keep it more driveable. With a good dyno tune, it sounds like a lot smaller cam. On the low end, the car is pretty much like stock. On the top end, though, it screams. It just keeps pulling harder and harder as the RPMs increase.
The coolest thing is the torque curve. It stays above 300 ft-lbs all the way from 2000 RPM to the 6400 RPM redline.
Originally posted by Z95m6
I would go with the 230/236 it should be more streetable then the other big cams listed.
Originally posted by BradZ28
I don't think anyone has the GM847 with Lloyds heads. That will be a 400rwhp combo if I've seen it.
-Rippin
custom grind?
whatever that means, I can't see anyting making more power then the 847 unless you had like 0 *'s of advance then yeah, but you need it for bottom end power, although I've seen cams retarded as much as 4 degrees, gain HP & maintain the TQ numbers across the board, weird.
I'll keep everyone posted.
