Headers for autocross/stock motor
Old Nov 12, 2003 | 04:45 PM
WOT's Avatar
WOT
Arrow Headers for autocross/stock motor
This is a little bit different question than most header threads. I autocross in ESP and in my class I'm not allowed engine mods. For a stock LT1 with intake and catback what headers would be the best? Lowend power is important. Thanks.
Old Nov 12, 2003 | 04:55 PM
drewstealth's Avatar
Mac's would be a good choice. I beleive the low end would be a better because they are only 1 5/8's primary. But i'm not 100% sure. Some people say with LT's the low end is better then shorties and visa versa.
Old Nov 12, 2003 | 04:58 PM
WOT's Avatar
WOT
That's what I'm confused about. I keep hearing that shorties or longtubes are better for low end. Not sure which.
Old Nov 12, 2003 | 05:36 PM
Yeah i always thougt that the LT's were better up top, and the shorties would be better on the low end. I'm pretty sure that is right also. I think some good Mids would be good for what you want. Either the AS&M's or Mac's. I think the macs would be a bit better though cuz of the smaller primary. Hopefully somebody else will chime in.
Old Nov 13, 2003 | 09:10 AM
WOT's Avatar
WOT
Thanks, anyone else?
Old Nov 13, 2003 | 09:34 AM
madwolf's Avatar
Get some AS&M mid-length coated headers. That's probably your best bet.
Old Nov 13, 2003 | 10:09 AM
lbrowne's Avatar
MACs!
Old Nov 13, 2003 | 12:03 PM
buelldevil's Avatar
Go with a mid length with a 5/8 primary tubes, any primarys bigger than that on a stock engine would place your power past the revlimiter.
Old Nov 13, 2003 | 01:38 PM
lt4 fd's Avatar
.....longtubes man, you gain power EVERYWHERE very noticable power in the low rpms and high, I have ram air and longtubes and where we started the dyno run at 2k torque was already over 305 lb/ft at the ground and goes up to above 325 by 3000, peaks at 3900 with nearly 340lb/ft and horsepower peaks at 5300, longtubes are the ****. ground clearance is reduced somewhat but as long as roads are good where you live you'll have no problems especially noton a flat parking lot where you auto-x. Although whatever exhaust you have wont work or will have to be slightly modified to work with the longtubes.... but if you have the money longtubes are the way to go.
Old Nov 13, 2003 | 01:39 PM
hsyr's Avatar
I would just go for longtubes They gave me a ton of bottom end over the stock manifolds and it pulls hard up top. I don't think there would be much of a difference from the bottom to the top to justify going with mid or shorties.
Old Nov 13, 2003 | 02:09 PM
Compstall's Avatar
Won't headers push you into a different class? They do up here.
Old Nov 13, 2003 | 04:48 PM
WOT's Avatar
WOT
No, headers are legal in ESP. They are NOT legal in FS. Legal in street prepared and up, illegal in stock classes.
Old Nov 13, 2003 | 05:37 PM
Compstall's Avatar
that's what I thought.
transam_388
Mar 15, 2015 11:53 AM
cmyname1
Feb 19, 2015 08:38 PM
Cam's maro
Jan 30, 2015 09:21 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
92ragtop
Dec 27, 2014 01:56 PM
