How many quarts of oil with PF1218 filter??
Old Nov 14, 2003 | 04:12 PM
96 WS6's Avatar
Do I need more than 5 quarts? It's a tad longer than the original PF25. I also have a blower but I was told that it did not use much oil... Ehh whats the consensus here?
Old Nov 14, 2003 | 08:03 PM
Bud M's Avatar
I don't remember exactly but I think it's 5 qts. It's not really that much bigger than stock, maybe 1/3 qt.
Old Nov 15, 2003 | 05:46 AM
Patman's Avatar
I use the K&N HP3002 oil filter, which is the same size as the PF1218, and I run 5.25 qts of oil.
Old Nov 16, 2003 | 10:12 AM
Why guess, or go by what someone else does? Fill the filter before you install it. Fill the crankcase, and check the level. Bring it up to the "full" line. Run the engine, warm it up and check for leaks at the filter. When you shut it down, wait 15 minutes and check the level again. That will tell you exactly what you need.
Old Nov 16, 2003 | 12:45 PM
96 WS6's Avatar
Will do Fred.
Old Nov 17, 2003 | 01:21 PM
arnie's Avatar
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Jul 4, 2005 05:00 PM
