Got 100,000 miles, what to do maintance on suspension, what should I look at/for?
Old Nov 11, 2003 | 09:14 PM
Joe Gee's Avatar
Howdy...
I got a little over 100,000 miles now and I want to look at my front suspension and steering components and see what might be worn out. I am going to put new shocks on it, but what else should I examine? What usually wears out?
Also what should I examine in the rear?
I also plan on getting an alignment. I want to make sure everything is sturdy under there before I take it up to them. My brother went to get his alignment done and halfway through they told him his idler arm and pittman arm were both bad and he had to pay anyway without getting his work done ... I don't want this to happen to me... btw: he has a truck and he got the rip job by the mechanic .
Joe
Old Nov 12, 2003 | 01:53 AM
slp223's Avatar
you might want to check you rag joint on your steering shaft. expscialy if you have headers. the burn and or wear out. causing slack in your stearing.
Old Nov 12, 2003 | 05:59 AM
slopokrodrigez's Avatar
The lower ball joints are probably trashed. They're a pain. Take the lower A arm to a shop and have them press new ones in. You might as well replace all the bushings while your there. I like my Eurothane bushings. Be careful what kit you get if you do get Eurothane. The one I got had to reuse the old metal sleeves with the new bushings and it took hours to get the old bushings out of the sleeves and cleaned to reuse them. I think my kit was from Energy Suspension but not 100% sure.
To do the shocks you will need a set of spring compressors.
Old Nov 12, 2003 | 06:02 AM
mc63's Avatar
I have 155,000 on mine and am in the process of replacing ALL the bushings front and rear. They are worn out.
I purchased a Energy Suspension Kit #ENS-3-18130G (Red Bushings) from Summit for $142.69 with free shipping.
Replace yours soon.
Old Nov 12, 2003 | 07:41 AM
Dave88LX's Avatar
You need to plan on a complete rebuild in about 10,000 miles. At least I did.
Old Nov 12, 2003 | 10:56 AM
mc63's Avatar
I hope you are not talking to me?
It does not burn a drop of oil and runs as good as the day I drove it off the showroom floor.
I guess it's all in how well you maintain them.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
