ABS/TCS quick question, info needed
Old Nov 14, 2003 | 03:19 PM
cfabes's Avatar
On LT1 cars, Is there one computer that handles ABS and traction control, or two seperate computers?
Does the traction control pump the rear brakes like it does on LS1 cars?
Does anyone know what abs system they use? Like the ls1 cars use Bosch abs 5.3.
Old Nov 14, 2003 | 03:25 PM
LWillmann's Avatar
LT1 Edit allows me to turn TCS off, and it allows me to adjust the timing retard for it. So I assume that it is all controlled by a single computer, the main PCM.
As for pumping the brakes, I can't say.
As for the type of ABS the car uses, all I know is it's a four channel ABS setup instead of the 3 channel the non TCS cars have.
Sorry I can't be more help.
Old Nov 14, 2003 | 08:17 PM
Zepher's Avatar
I know that TCS equipped LT1 cars have different axles and disc brake backing plates.
There is a reluctor ring on the axles and the backing plates have a provision for a sensor.
Hurin
Dec 13, 2014 07:38 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
Brent94Z
Mar 21, 2002 04:44 PM
