Help make my car run!
Help me let me explain what happened, I was driving on the highway and all of sudden the car just died on me w/o warning! I first thought opti(2nd one) and yes it was bad so I got a new one from GM, I have replaced the pcm, fuel pump, wires plugs, ingition control module, coil, waterpump before all of this, I have checked all the sensors and conections. I try to start it now and its like it is not getting any spark at all but it gets gas just fine. Its not throwing any codes right now (have a cable and labtop) So is it my ignition should i get a msd box any suggestions help I am currently borrowing a car and I have to replace a fuel pump in a van cause it just went bad. Thanks guys!
well guys I am going to hit the hay cause its to cold around here! Shoebox do you think it could be the ign switch? The car is a Daily Driver and has 120,000miles see you all in the mornin--maybe I will get an early christmas present and the car will just start in the morning! LOL
You may think this stupid or strange...but is your intake on tight? I had the same problem and it was usually do to my intake shifting ang comming apart. Check the cars vaccums...could be a vacum related problem. When my car was doing that it was a Vacum leak on the intake. Didn't even register on the GM Tech 2 wierd hungh? Mainly because it broke loose from the engine vibrations ...but when it shut off it somehow shifted back into place. wierd...I know...but possible...yes...sounded very similar to your story.
I will try the opti test. I think the opti harness is just fine but who knows. I checked for leaks on the intake and it is just fine, I have started in before with the cai off so I do not think that is the problem. but thanks!
1996LT1Z28
Dec 4, 2014 09:20 PM
ro2207
Dec 4, 2014 06:18 PM
