I need help fast
Old Nov 13, 2003 | 07:23 AM
DamianLT1's Avatar
I need help fast
I have a low oil sign but I can't the leak. Now I thought it was the infamoun manifold leak so I had that all redone at Cartek in NJ which is a Fbody performance. A month has pass by and I get the low oil lamp. Once again I"m like 2 quart off. Where is the oil going?
Old Nov 13, 2003 | 07:29 AM
joeSS97's Avatar
If its not leaking,it is going out your exhaust.Worn valve seals,and or rings.
Old Nov 13, 2003 | 07:39 AM
DamianLT1's Avatar
The heads have new parts.
Old Nov 13, 2003 | 07:43 AM
joeSS97's Avatar
That leaves the rings.
Old Nov 13, 2003 | 07:54 AM
DamianLT1's Avatar
anyway to be 100% sure that its one or the other? How could I check it?
Old Nov 13, 2003 | 07:57 AM
Dave88LX's Avatar
Compression check maybe? You can do your spark plugs at the same time.
Pull
Old Nov 13, 2003 | 08:01 AM
DamianLT1's Avatar
Here's what I had done to my heads about 3 months ago.
Valve 1.940" IN / 1.500" EX Manley Stainless
Springs 1.250" Double Installed
Seals- Umbrella
Lock & Retainers 7 degree Comp Cams
Old Nov 13, 2003 | 08:02 AM
Dave88LX's Avatar
I fail to see any mention of PORTING!
Old Nov 13, 2003 | 08:38 AM
DamianLT1's Avatar
Valve Job 3 angle
Stage II porting
Seals- Umbrella
Milling .005"
Flow- 235 cfm IN / 180 CFM EX @ .500" lift
Old Nov 13, 2003 | 11:21 AM
DamianLT1's Avatar
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
