Any tips on removing the EGR valve?
Old Nov 12, 2003 | 10:34 AM
SteveSS's Avatar
I found it I think. Very back of the intake manifold, driver's side. I can get the wire off but how do you get the valve off? It's very tight back there. I heard you can check it by pushing the valve back and forth and possibly save it by cleaning the carbon off. Any tips pn removing it?
Old Nov 12, 2003 | 10:38 AM
Mike383LT1's Avatar
egr valve
it is held on with two bolts easy to get to with a short wrench are you replacing it or eliminating it if you are it must be programmed out
Old Nov 12, 2003 | 10:40 AM
SteveSS's Avatar
Cleaning or replacing. I want to keep the car stock.
Old Nov 12, 2003 | 10:43 AM
Don 97 SS's Avatar
I use a 1/2 inch open end/ box end wrench to remove the two nuts on the EGR studs. Be careful when removing the valve not to damage the gasket so it can be reused.
Old Nov 12, 2003 | 11:49 AM
94BlackBowtie's Avatar
You may also want to get some of the copper gasket stuff - to avoid any little annoying exhaust leaks - especially if the car has any amount of miles on it at all (50k+)
Old Nov 12, 2003 | 01:44 PM
TMD95Z28's Avatar
it should be at the passenger side right??
i guess it should be easy if u have a little hand like mine..
goodluck
Old Nov 12, 2003 | 01:47 PM
Don 97 SS's Avatar
Wink
goodluck
I found it easier to access from the pass side of the engine.
Small hands and thin arms are generally an advantage when working on an f-body.
Old Nov 12, 2003 | 02:34 PM
Heatmaker's Avatar
Advanced Member
It's easier to get off than you think it is...shouldn't take more than 5 minutes. Use the mini rachet
Old Nov 12, 2003 | 04:02 PM
moparman's Avatar
You could get an inspection mirror and flashlight and take a look so you can see what's up.
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
jocamino
Dec 29, 2014 10:15 PM
