Comp 224/230 Cam Q's
Old Nov 13, 2003 | 07:39 PM
94z6410's Avatar
I am planning to install a Comp cam 224/230 in my 94 z28 with stock heads. Do i need 1.6 rockers or can i use the stock rockers? If i do use the 1.6 rockers, will i need to have the valve seats redone when i change the springs to handle the new rocker?
Old Nov 13, 2003 | 08:02 PM
Javier97Z28's Avatar
Moderator
Don't skimp on the project, go with the rockers.
cmotorsports.com has a custom set of springs with a complete cam package that goes great together with the 224/230. No need to touch the heads to accomodate the springs..
and it's a good deal too
Old Nov 13, 2003 | 08:36 PM
94z6410's Avatar
I agree about the rockers, might as well do it all while it is apart. Thanks for the information.
Old Nov 13, 2003 | 09:12 PM
neil350's Avatar
If your low on cash you can hold off on rockers, that what I should have done, but oh well lets not get in to that.
Old Nov 13, 2003 | 09:18 PM
Fastbird93's Avatar
You can use the stockers, but why?? If money is the issue, then don't worry about it. but if you can afford the new rockers, then take care of it while it's apart.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
drptop70ss
Mar 26, 2015 01:50 AM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
