Any way to have a quiet valve train with 1.6 rr's?
Anyone know of a way to have a nice, quiet sounding valvetrain with rr's?
Is it the fact that they are rr's, or that they are 1.6 instead of 1.5?
Also, Self aligning are noisier than non self aligning correct?
Are there any 1.6 rockers that are not roller rockers? Are they safe to use with a cam like the CC502 or CC305?
I really would like to minimize the possibility of having a clacky engine.
Thanks,
Dan
Thanks,
Dan
Thanks Brandon. Besides covering up the noise, is there a way to keep it from happening in the first place? That would be my first choice if possible.
I'm very conservative on what parts I want to buy. I want my car to perform well, but I also want it to sound like a well tuned engine. I don't want to pop the hood and hear clack, clack, tick....
Any way to get away from that? I'll sacrifice a little performance if I have to.
Dan
Dan
So RR's aren't always loud. That's cool. I was under the impression that they are noticable when you install them. I wonder if different brands are worse than others for noise, CompCams, GMPP, or Crane.
Also, am I right in thinking that the non self aligning are quieter that the self aligning ones?
Thanks,
Dan
Thanks,
Dan
Thanks,
Dan
Thanks,
Dan
Aaron
Well, 1.6 rr's are always a little bit noisier than stock 1.5 non-rollers. You can notice the difference but it is not to the point that it is annoying. Once I start driving with my flowmaster and no CATs, I can't hear them at all!
Jegs sells stock design 3/8 stud Crane Cams stamped steel 1.6 rockers #270-11802-16 for $91.99. I'm also thinking about 1.6 rockers for some extra horsepower but am willing to sacrifice a little top end performance for everyday quietness. Jegs also has roller tipped 3/8 stud 1.6 rockers #270 11807-16 for $171.99.
2cub49,
Thanks. At least now I know that the 1.6 rockers do exist. That's good to know in case I decide to go that route.
What would I be loosing out on going with 1.6 rockers instead of 1.6 rr's?
The stamped 1.6 rockers would still be safe to 5700 rpm right? I really don't plan on spinning too high with my new cam when I get it. Would it be o.k. up to 6000 rpm with stamped rockers? The cam is probably the CC502 and I would replace the springs as well. I wonder if there would be enough clearance for the new springs with the stamped 1.6 rockers?
Thanks,
Dan
Thanks,
Dan
Crane and comp make a roller tipped design that really reduces the valve tip and guide wear. by going roller tipped over full roller you lose hardly any at all. the biggest asset of full rollers is less recip weight and lower oil temps. I have had Crane golds (self and non-self), TRWs,Harland sharps, Elgin,and comps steel full rollers and their roller tippeds, I didnt notice any extra noise from the roller tipped ones,but the fullrollers all made extra noise.
