fixing intake leak
Old Nov 12, 2003 | 03:39 PM
red 95 z28 lt1's Avatar
fixing intake leak
ok my mechanic is going to fix my intake leak. i was wondering what mods are worth doing while the intake is off. he said he could port and polish the intake for better flow. should i put bigger fuel injectors(22#) with a new fuel rail. would i get any power out of these mods and is there any more mods i could do
thanks
also the heads are staying on. mods in sig
Old Nov 12, 2003 | 03:57 PM
1badasZ's Avatar
not sure but i think the stock ones are #24 so that would be going down. and why would you need a new fuel rail and as far as the porting it might not really help but if its free or cheap i guess go for it..im not sure but thats just my .02
Bastardcat's Avatar
IMHO getting bigger fuel injectors w/ a new fuel rail would be useless with your current mods.
Old Nov 12, 2003 | 03:59 PM
well is there any mods i can have done while my intake is off
Old Nov 12, 2003 | 04:02 PM
1badasZ's Avatar
a cam if you go a lil more into it
Old Nov 12, 2003 | 04:27 PM
i dont wanna touch that section of the motor right now untill my opti goes thats when i will do a cam along with electric wp opti and new timing gears. theres gotta be some mod that can be done while the intake is off
Old Nov 12, 2003 | 04:29 PM
doodad's Avatar
I am going to powdercoat mine while it is off.
Old Nov 13, 2003 | 04:54 PM
is it ok if i get it ported and polished now because im gonna do heads and cam in the near future
Old Nov 13, 2003 | 06:37 PM
S.J.S.'s Avatar
you can match port the intake to the heads, but your not doing the heads so I see no purpose in that. As far you mechanic said about polishing the intake.....you don't wanna do that. The intake should be sanded with 80 grit at its finest beacuse you need a slightly rough surface for the fuel and air to atomize (is that the word) properly.
Old Nov 13, 2003 | 07:00 PM
ok
Old Nov 13, 2003 | 11:31 PM
96 WS6's Avatar
You can pop the valve covers off and put 1.6 or 1.7 roller rockers along wth some new valve springs... there is a really good install guide by street illusions. With the intake off it takes less than 5 minutes to remove the valve covers.
Old Nov 14, 2003 | 06:54 AM
wouldent i have to modify the valve covers for clearance. also which is better 1.6 or 1.7 rr's? what brand is the best. and what type of gains will i be seeing?
thanks
Old Nov 14, 2003 | 11:32 AM
anyone?
Old Nov 14, 2003 | 11:35 AM
Bastardcat's Avatar
No.
Old Nov 14, 2003 | 11:49 AM
DamianLT1's Avatar
I would hold off on the injectors. You're not making enough power to need them. You will not need then until a cam swap.
