How can I test my CSI to make sure it is working??
Old Nov 11, 2003 | 09:06 PM
96 WS6's Avatar
I thought that if I hooked the power up straight to the battery and had the pump grounded it should start working right? Does the batt. need to be connected? It did not even make a noise or try to work and it's a brand new CSI pump untouched unscratched new in wrapping and box. It can't be messed up I must be doing something wrong. Please enlighten me, thanks.
BTW, I do have a relay and I have everything wired including a status LED I just wanted to make sure the pump worked.
Old Nov 11, 2003 | 09:16 PM
AsianSensation's Avatar
I tested my Meziere before I installed it to make sure it works. I put the hot wire (one with the inline fuse) to the positive battery terminal and grounded the other wire. I wouldn't run it dry too long. And yes, the battery has to be hooked up.
Old Nov 11, 2003 | 09:21 PM
atljar's Avatar
If you touch one wire to pos terminal of battery, and one to negative, it should spin.
Old Nov 11, 2003 | 09:53 PM
funina91ss's Avatar
Re: How can I test my CSI to make sure it is working??
you need to hook the ground up or ground the wire coming off the pump to the - terminal to complete the circut.
I used a 30amp relay to run mine when the key is in the "run" postion.
Old Nov 12, 2003 | 03:31 AM
96 WS6's Avatar
I'm such a dumb head... for some reason I forgot that the ground needs to make it's way back to the battery... that would be kinda hard with the ground disconnected. The pump works fine, thanks fellers.
Old Nov 12, 2003 | 03:41 AM
b84camLT1's Avatar
Not to hijack your thread, but i'm about to buy a csi and was curious how you are liking the install. Also, what do you guys use to plug the hole in the timming cover? thanks.
Old Nov 12, 2003 | 06:16 AM
96 WS6's Avatar
The install was simple. You just need a grinder to take some material from the inside of the water pump housing to fit the pump. Other than that it's really easy. The Ken Lowrance guide has provisions for plugging the hole. Basically you flatten the inside of the cover so that the area behind the hole for the water pump drive shaft bearing is flat. Then you using two washers and some RTV to seal it with a nut and lock washer. Simple contraption but works well. I used a 3/8 washer on the outside that I shaved down a teeny bit and it fit that hole perfectly.
Old Nov 12, 2003 | 06:32 AM
funina91ss's Avatar
My pump came with a plug (looks like a small frezze plug) you just tap it in the back of the housing. I used some RTV to make sure it got a good seal.
Old Nov 12, 2003 | 07:02 AM
96 WS6's Avatar
He said the hole in the timing cover not the water pump housing.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
siguy
Nov 27, 2014 10:07 AM
naaz90
Jul 27, 2002 08:22 AM
