whats a good cam to go with???
what tranny do u have? i would recommend at least a 2800 stall if an auto, if you plan on turbo/super charging later, you should look at those special grinds with a bigger split in duration. i havent really got a chance to see how my cam/heads perform, my tranny blew after 2 wot blast
jesse
jesse
Do a search on the subject and find what others have said. After you read a few, you start getting an idea what you want for yourself. Regarding cams, you will have hours of reading!
I found that little search button to be a helpful friend.
GL.
GL.
Thanks guys, I am going to be building a motor just for turbos later down the road, I am just doing this now becasue it is a bit cheaper than 15,000 dollars. I am running an auto, and was thinking a 2500- 2800 stall would be perfect
oldschool
Feb 9, 2016 09:21 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
