2.73 to 3.73 gears
Old Jun 30, 2003 | 02:54 AM
Detroit808's Avatar
2.73 to 3.73 gears
I have a 94 z28 convertible A4 with 2.73 gears. First off, it has a stock rearend...is this the 2-series 7.5" 10-bolt carrier? I read in another post that I can keep the stock rearend as long as the aftermarket gears are specifically made for my carrier type, correct? Also, will there be any danger of running 3.73 gears as a daily driver, or would 3.42 be any more reliable? I don't want anything else breaking prematurely! A local shop quoted me $1400 for everything plus installation. This quote seems very high according to what others are telling me. I'm thinking of just ordering a "complete kit" off the internet (for around $500) and getting somewhere else to install it. Do I need anything besides the kit, and what should I be paying for the parts and installation separately? Thanks.
Old Jun 30, 2003 | 05:45 AM
OrionSPL's Avatar
You can get 3.73 gears for your rear and as long as you get someone reliable to put it in you will be fine. A 3.42 isn't going to be any more reliable then the 3.73 if you have an idiot put it in. You will be wasting more fuel with 3.73s but I think it is a good gear for us A4 guys. You will also need to change your gear ratio in your computer.
$1400 sounds a bit high. If you plan on paying that much I would wait and save another $800 and put in a Moser 12-bolt. Very easy to install yourself. If you were to buy a ring gear and pinion kit I would assume this would be around $350 for a decent kit. Make sure you get a kit and not just the ring gear and pinion, there is more that is needed for installation. I would also assume a shop could install this for you for $250-$300 tops.
Old Jun 30, 2003 | 09:00 AM
CrockRocket94's Avatar
I got my 3.73s installed at DTS (Drive Train Specialists) in Warren, MI for 225+ synthetics.
Gears do not whine at all.
Old Jun 30, 2003 | 09:35 AM
383Z4ME's Avatar
I just got a Richmond 3.73 to replace my 2.73 in a A4 car. I love the gear on the street. It made absolutely no difference to my mixed highway/city mileage. It stayed right at 15.3 mpg. I drag race and the gear will force me to run a 27" tire if I start running any faster. I have trouble hooking now, too. I would have been better off with 3.42 at the dragstrip I think. As far as price I saw similar (500.00+) packages for Moser or Srange gears. The guy I had do the job laughed at me for wanting expensive name brand and then charged me 620.00 for the same parts from Richmond. (I know I should have gotten a written quote). I checked on the internet and that is about the going rate for the Richmond gear and install kit. I think they charged me 340.00 labor which is on the high side. Labor should be 260.00 to 360.00. The gear does make a little more noise then factory gear. Installer was concerned but Richmond told them F-body is like that because of torque arm.
Old Jun 30, 2003 | 09:47 AM
383Z4ME's Avatar
I checked the pricing I had. This is from Richmond. Gear was 200.00. Install bushings and shim kit was 120.00. I bought a TA cover from Thunder Racing for 155.00 and bolt set for 25.00. I did pay 340.00 labor for the gear install. My 620.00 in previous message included brake pads and a couple of other things.
Old Jun 30, 2003 | 11:35 AM
94droptopz's Avatar
if youll look on the net for some instructions its not that hard to install your own gears. its definantly not 320.00 bucks hard. give it a shot. if you cant do it,then take it to somebody and pay the labor.
Old Jun 30, 2003 | 01:16 PM
5thCamaro's Avatar
I paid 800 for a eaton posi,3.42, and all labor.
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
blac94Z
29
Mar 25, 2015 04:21 PM
