typical price for heads and cam
Old Jul 1, 2003 | 02:13 AM
96birdlt1's Avatar
I have pretty much decided to get my heads ported and polished by Lloyd and get a LT4 Hotcam kit installed. My question is can I also get headers installed and stay around the 3500 dollar mark?
any help would be great.
Joe
Old Jul 1, 2003 | 02:39 AM
93formula's Avatar
are you doing the work yourself? if so yes. head porting 1500 hot cam kit , ive seen them go for 250. misc gaskets etc. your way under 3500.
Old Jul 1, 2003 | 03:03 AM
96birdlt1's Avatar
I haven't done a cam before, so instead of messing something up, I will probably have everything installed at once.
Old Jul 1, 2003 | 04:38 AM
unTAmedLS1's Avatar
I picked up xe cam 224/230, 1.6rrs, new timing chain, hardened pushrods, valvesprings, retainers for 658.00, Long tube headers 472, heads ported by me, head cleanup and 3 angle valve job 180.00, misc gaskets and fluids like 100.00. Pulling 3 cars on a stock ZO6 w/ a car that doesnt even have 10000 invested including buying it......
PRICELESS
Old Jul 1, 2003 | 06:40 AM
slopokrodrigez's Avatar
I haven't studied it closely since I did my engine parts from many different sources but...... Take a close look at the GM Performance parts kit in Summit. It's part number NAL-gmp3287-1 or -2 depending on year.
The kit includes heads w/valves and springs, cam, intake, 1.6:1 roller rockers and all the gaskets and seals you need for $2290.00. Well worth looking into and they claim it's good for 425HP+
Old Jul 1, 2003 | 08:20 AM
Smoke T/A's Avatar
I sent you an email about the install. I have done plenty of head and cam swaps on LT1's and I can get you refrences if you'd like.
LMK
Joe
Old Jul 1, 2003 | 09:29 AM
96birdlt1's Avatar
If I'm not mistaken the kit with the heads and everything is a LT1 to LT4 swap. The heads would still need to be ported and with install and with headers and tuning and misc... would put me well over 3500. Most of the people on this forum say that you can get almost as much power from the LT1 castings and a cam swap for much less $$
Maybe I'm setting my hopes too high, but I would like to stay around the $3500 area, and get as much done as possible.
Smoketa, sent you an e-mail.
Joe
Old Jul 1, 2003 | 11:26 AM
Smoke T/A's Avatar
Joe
I would stay with the stock castings and get them ported to save money. Even though Lt4 heads will out power the LT1's when they are both ported. I think a lt4 conversion, install, headers and porting of the heads will be over $3500.
Old Jul 1, 2003 | 02:32 PM
Fastbird93's Avatar
It all depends on what you do. My total is as follows:
Extra set of heads: $250
JPR Porting to include Manley 2.02/1.56, Tit retainers, springs, seats: $1300
Extra Manifold (93) and Powdercoating: $140
Vented Opti Swap Kit including Mezier and Cloyes: $745
224/230 Cam: $225
Chromemoly Pushrods: $108
Pro Mag 1.6 Rockers: $259
Comp rocker Studs: $25
Comp R lifters: $223
Accel 300+: $230
BBK 58mm TB: $320
Installation via JPR: $1000
Recoating of Headers: $150
Gaskets: $100
Dyno Tune: $400
Grand total: A forged 396 shortblock $5475
Granted, I could have saved some serious coin doing the install myself (no time or expertise though I could have done it), not recoating the headers, no dyno tune, cheaper pushrods, and no 300+, but I wanted everything done right the first time.
So, all depends on what you already have or don't, and what you want to put into it.
Old Jul 1, 2003 | 03:01 PM
96BlackTA's Avatar
http://www.cmotorsports.com
Havent personally ordered from them but the prices on their heads/cam packages looks like a real deal to me.
Old Jul 2, 2003 | 01:46 AM
unTAmedLS1's Avatar
Thats where I got all my stuff. Best place to deal with and great prices too actually the best prices at the time
Old Jul 2, 2003 | 03:02 AM
num's Avatar
num
www.gmpartsdirect.com sells the same kit for $2,091. bit cheaper than summit.
P/N pk12550630
Old Jul 2, 2003 | 07:13 AM
my94blackz's Avatar
$500-heads worked with all new everything
$200-used hot cam
$150-misc items
Heads were done at Bucks Racing in King, North Carloina. Home of Tricky Ricky Smiths Pro Mod engines.
Old Jul 2, 2003 | 04:30 PM
AlexsZ's Avatar
$918 - XE236/242 cam, pushrods, springs, locks, retainers, 1.6rr's, head gasket, header gasket, lifters
$1400 - port/polish heads, 3 angle valve job, 2.00/1.57 valves, ported intake
$378 - 30#injectors and 255 lhr Walboro in-tank fuel pump
$440 - Jet hot long tube headers
$250 - LT1 edit expert edition with logging tool
$100 - LT1 edit cable from akmcables.com
$120 - OVC loom kit (plugs, wires, strippers) from thunderracing
$103 - Vortech polished elbow
$3709 for everything
oldschool
Feb 9, 2016 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
