Removing steel plug from aluminum LT1 heads
Old Jul 27, 2015 | 09:25 PM
4586's Avatar
Any suggestions for removing the steel square hole pipe thread plug from a 95 LT1 aluminum head?
Have the engine up and running in a 37 Chevy and need to leave the OEM temp sender on the drivers side... would like to install an aftermarket temp sender in the plug hole on the passenger side head for the dash temp gauge.
Torqued a little with a square head socket via a 3/8" drive ratchet...but just get that "feeling" that I need to back off before something breaks
Do have coolant in the block...any suggestions?
Old Jul 27, 2015 | 10:16 PM
Re: Removing steel plug from aluminum LT1 heads
I believe the size of the square is 5/16", just so you don't round it out.
Old Jul 27, 2015 | 10:18 PM
4586's Avatar
10-4... I even have a Snap-On square socket for the plug.
Old Jul 31, 2015 | 06:03 PM
4586's Avatar
OK..got out today! Thanks...
*Emilia*
May 13, 2015 09:05 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
