94 z28 coolant sensor leaking??help
Old Jun 27, 2015 | 04:22 PM
colts0455's Avatar
ive messed with this thing past few days put new o rings on it so on still leaking ?? whats next
Old Jun 27, 2015 | 08:12 PM
Re: 94 z28 coolant sensor leaking??help
"New Member Intro" isn't the best place to get tech help. Let's move this to "LT1 Based Engine Tech" where you already have a post.
Coolant temp sensor or coolant level sensor? Suspect its the level sensor, since the others are screw in.
Old Jun 27, 2015 | 08:45 PM
colts0455's Avatar
yea im sorry i dont do blogs alot super new here its the low coolant sensor thats near the battery its nothing more than unplug and pull out got 2 o rings on it that link shows what im talking about
Old Jun 27, 2015 | 08:47 PM
colts0455's Avatar
MasterPro Ignition 2CLS1 - Coolant Level Sensor | O'Reilly Auto Parts
Old Jun 27, 2015 | 08:48 PM
colts0455's Avatar
^^^ ok sorry that's it
Old Jun 27, 2015 | 08:59 PM
94Z28LS1toLT1's Avatar
Should just snap on n clip too mine poped off bcuz I bumped it accidentally
Old Jun 28, 2015 | 08:15 AM
colts0455's Avatar
yea i took it off put new o rings cleaned it off good pushed it in good went for about 15 mile drive pulled back home leaking bad
Old Jun 28, 2015 | 08:40 AM
Are the two metal clips snapping on right bcuz u should hear a click that's y mine came off the clip should go over the part on the radiator
Old Jun 28, 2015 | 09:35 AM
Is it leaking at the O-rings, or through the body of the sensor? The coolant seems to penetrate the seal, contaminate the PC board (which causes a false "low" reading). Once it's in the body, who knows where it will go.
Courtesy of Shoebox:
http://shbox.com/1/low_coolant2.jpg
Old Jun 28, 2015 | 09:55 AM
colts0455's Avatar
ill check and see if the clips are snapping a ? about that when its off can i put the clip on it and then push it back on ?? or push it on then try put that clip on then ??? and injuneer its really hard to tell i just know its leaking from that sensor cause can see water shooting i want to say around it why i thought was 2 lil o rings but ive replaced then 3 times ?? also thanks for writting back yall ill take all info i can get
Old Jun 28, 2015 | 10:52 AM
I would make sure it is all the way into the mounting neck, then install the clip. Shoebox's photo may help.
I assume you cleaned any sludge and corrosion out of the mounting neck.
Old Jun 28, 2015 | 01:09 PM
Make sure the seals are lubricated with some coolant, so they don't "roll" when you install the sensor. The clip should snap on when you install the sensor, but you will have to look carefully to make sure it did. If the rings are just not large enough to seal, you can take them off and put a few laps of teflon tape under them and put them back on. That will expand them a little in hopes of creating a better seal.
Old Jun 28, 2015 | 02:16 PM
colts0455's Avatar
hey thanks guys i just took it off now getting new seals ill update soon as im done
Old Jun 28, 2015 | 03:15 PM
colts0455's Avatar
update im guessing someone messed with it b4 and put to big seals in it ? its got a hair line crack on the top of the neck it slides into is this bad ????
Old Jun 28, 2015 | 04:24 PM
Is there a crack on the radiator is wat ur saying
