oil pressure help
oil pressure help
I have a 97 LT1 with 80K on it. I bought it used and the person before me put the LT4 hot cam in it. Just recently It dropped a valve so i pulled the heads and ported them and also changed to a bigger cam. After it was put back together it ran fine for about 500 miles with great oil pressure. Then I noticed at idle the oil pressure kept getting lower and lower until it only held a few PSI. I confiremed this with a mechanical guage. My question is when i changed the cam i used the stock lifters. I noticed when i pulled the valve covers all the rockers had oil coming out except for one, It had oil gushing out of it. Has anyone had a lifter go bad and cause this? When i first put the motor together all the rockers had the same oil coming out. Now i have low oil pressure and the one gushing oil.
There was a thread a few weeks ago about oil that would spray from one rocker arm out past the fender. The fix was replacing the internal pieces of the lifter with a used parts the guy had laying around. He didn't have low oil pressure issues...
My guess is you need another lifter, but the damage might already be done.
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
