Leak fro Above Oil Filter
Leaking oil from above oil filter. I have oil prssure guage and Pro Charger plumbed into the 1/4" NPT hole jsut above the filter. I just took all that apart and put together with teflon tape...... definetately not leaking from there.
Took inspection mirror to the back side of the head / valve cover and intake manifold, and appears to be dry from the top.
Is there a block plug in the area that would cause oil to leak from above the oil filter (other than the one mentioned below)??
Not ******* my car, but I seem to chase oil leaks constantlly on this LT1 motor.
Thansk for your input!!
Thomas.
