yet another cam question
Well my 355 is getting closer to being complete. I'm going for a higher reving 355 for road racing, aiming for 6500-6800 max RPMs. right now i have a comp 224/230 112 lsa cam in the motor from the last setup. Should I consider a new cam? I've read alot about the comp 306, is that a better option?
A cam in the mid to high 220 duration range might allow you to 'rev" to 6800 RPM but it will be done making power before then, I would suggest something in the low 230 duration range and maybe a mid to high 230 duration range depending on where you want the power band to start at.
Lloyd
Lloyd
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
