Exhaust popping...
Old Aug 4, 2008 | 02:43 AM
twcblackhand6970's Avatar
Exhaust popping...
Whenever I'm cruising on the highway at about 2500-3000rpm with no throttle (highest I've cruised at, just got car back) and then I push the throttle it the exhaust makes a popping noise when I first press the throttle. The popping noise sounds like some car's exhaust when they are decelerating. What could cause this?
Old Aug 4, 2008 | 08:09 AM
seawolf06's Avatar
A rocker out of adjustment or an arcing/failing spark plug wire would be my first thoughts. Does it feel like it has full power at WOT?
Could just be your exhaust setup.
Old Aug 4, 2008 | 08:29 AM
bowtiekid's Avatar
Its just your exhaust setup. Cuz when I do the same thing it pops like crazy. No worries.
Old Aug 4, 2008 | 08:52 AM
Mtxz453's Avatar
Absolutely not. Your car should not be popping/backfiring when accelerating, and it'll greatly effect the performance and gas mileage of the car. That popping noise is from raw fuel not igniting in the cylinger and in turn hitting the headers and making that backfiring noise. If it is a backfire/popping while accelerating it is most likely some sort of ignition issue, whether its old spark plugs and/or wires, bad opti, or bad ICM. When was the last time you replaced any of those?
Old Aug 4, 2008 | 12:13 PM
I just got the car back from my mechanic, he replaced the spark plugs because the plugs were bad. Under WOT it feels full power.
It only pops when I first press the gas, not the whole time I'm on the gas.
Old Aug 4, 2008 | 01:37 PM
Mtxz453's Avatar
i'd have to hear the "popping" that your talking about. If it sounds like a backfire, thats not normal under acceleration.
Old Aug 4, 2008 | 02:03 PM
bowtiekid's Avatar
Its not bad. He didn't say under acceleration if you read his post. He said with no throttle and then when he first pushes the throttle it pops. That would be backpressure in the exhaust. Its nothing bad. My car does it ALL the time on the freeway. Its not what your thinking.
Old Aug 4, 2008 | 02:51 PM
Mtxz453's Avatar
I took it as a backfire type noise. I have magnaflow and I have never experianced it but maybe it's something with your exhaust then. bowtie, do you have the same system as him?
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
