$250 to spend on heads for clean up/port is it worth my time
Ok I'm gonna be installing a hotcam kit in a few weeks, since I'll have the engine torn apart, I was thinking of having the heads cleaned up or ported, the only thing is I have a 250 dollar budget. I might come up with slightly more money but not much more. Being this is not very much money, is it even worth my time to take the heads off and have work done to them. I'm not sure how much money shops charge, I only want mild port work since my future upgrade will be an ATi supercharger
Thats EXACTLY what im doing...
i picked up a hotcam kit and i picked up a set of heads that were cleaned up/midly ported....
i dont want heads that flow alot b/c 1. i dont have the money and 2. i dont want that much power and b/c the cam is on the smaller end ..
so cleaned up heads are good enough for me
Originally posted by Max 93
don't forget to figure $60 into your budget for new head gaskets
also, i might get the impala ones, so different compression
You may not want to use the Impy gaskets as they are designed to seal iron heads to an iron block. They react differently to the aluminum material in an LT-1 aluminum head (like a Camaro for instance).
Originally posted by Dr.Mudge
Even if you "only" see 20-30 HP or so, is that not bang for the buck? A pocket port should be fairly quick and easy for them, if they know what they are doing its worth it.
