Detonation!
My '97 is almost completely stock (!!) at 68,000. Has had EGR campaign performed at dealer about 1 year ago. Knocks on premium fuel (even with octane boost and 2 gal. of 100 octane!) at part throttle after warm-up. Replaced 180 therm. after overheating problem - cured overheat but not spark knock. Dealer mech. suspects EGR port blockage(haven't checked). Was wondering about simple carbon build-up? Cleaning suggestions? Problem seemed to start after install of 255/55R16's - much taller than stock - reprogramming necessary to compensate?
Has the knock system been checked? There is a procedure to check the sensor while it's on the engine with a volt meter. I don't have the book in front of me so I can't remember. May be some one can volunteer that if you reply. I know it will detect a slight rapping with the back of a screw driver and the meter will show when you do. But beyond that I forgot.
Also do you have access to a scanner? The Snap-on one shows total advance when running in real time. Could be helpful to see what's going on. Maybe a local mechanic has one and is willing to hook it up to check. Just a thought
I hate detonation problems with these cars....FWIW...I have been having detonation/preignition/something like that problems for about 6 months. I have changed every sensor, plug, wire, liquid...seafoamed everything, bought AutoTap and LT 1 edit. NONE of it has fixed my problem. I dont have any clue as to my problem either. Mine detonates from about 1400-2400 rpm in any gear....then it goes away till the next gear at that rpm. Well, I hope you/I figure out our problems. Im guessing that since programming doesnt help it...that my problem is internal (gasket leak ??). Hope someone can help us.
Get back up there!
Get back up there!
n2oTransAmLT1
May 14, 2003 08:02 PM
