What is the cheapest adjustable fuel pressure regulator?
Hey everyone, just wondering who makes the cheapest adjustable fuel pressure regulator, and what everybody thinks of the different brands. Thanks!
Originally posted by RamAir95TA
Why do you need one? The PCM will adjust injector pulsewidth shortly after you modify the pressure, so any changes will be negated.
I just ordered an AFPR (Racetronix fuel pump upped pressure to 46psi) - I went with the Aeromotive AFPR. It is $140, but I had bad luck with a cheaper one a couple years ago. Thought I'd just buy the best piece that will even work in a blown environment (ups FP based on positive manifold pressure, AKA, boost).
-Alex
Even on a stock car?
In that respect, you are correct. But, who's stock?
-Alex
Look at his sig one more time...
'96 Trans Am, Stock as a block; 17X9.5 GMMG ARE 200S Wheels; MAC Progressive Rate Lowering Springs
The 355 is in the process.
-Alex
It's been parked since November.
