Where to get Opti Sensor?
Converting to the vented Opti will be a pretty big job. You need to install a cam that has the longer driveshaft dowel pin that seats on the back of the opti. You'll need to pull the intake, fuel rail, radiator, water pump, cooling fans, opti, timing cover, timing chain, valve covers, rockers and valvetrain, and then the cam.
It's a pretty big job, and only worth it when you decide to install an aftermarket cam to begin with.
Get an unvented
Order through Jason Cromer or Dal Slaubaugh(sp?)
Wires? OEM replacements have worked great for me and some others, it depends what you plan on doing
Plugs? Are you staying NA, if so I like the oem ones as well, going with some n2o get some NGKs.
