BeCool Radiator fitment problem
Hi folks,
I ordered the Becool radiator 60028. It's in perfectly, except the Oil Cooler Bypass Line (#16 http://shbox.com/1/95-97_hoses.jpg) does not fit. The radiator has a threaded hole where the hose should connect. Anyone put in a BeCool and run into this problem? I'm not seeing any kind of adapter available.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
You can block both off no problem.
