94 z28 wont run after 10 mins
I just got a 94 z28. After 10 mins of running it will start to misfire and then die out. I wont restart until a day later. I thought the control module first, but i changed that and it didnt fix it. Any ideas. Its all stock.
Ok, so i ran the camaro with a timing light. It ran fine for 5 mins. Then it started to miss bad. No.3 was missing at idle but when i gave it a little gas it got worse. No.1 was missing too but not as much. Then i put the light on the coil wire. I was missing as well. So i figure the optispark since the coil wire was missing during idle. What do you guys think?
Think about which components can break down as they heat up - coil, IC module, and the Opti optical module.
The Opti opitcal module, and the IC module can set codes. Have you scanned it for codes?
I had this exact same problem. Tested out everything and was getting a weird pulse on my test connector. Changed my optispark and problem is completely gone. The only code i had was a code 36 high res failure. hope it helps
Jan 5, 2015 07:14 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
