High volume vs. High pressure oil pump
Old Feb 10, 2010 | 08:14 PM
mrl510's Avatar
Im trying to decide which to get. Im building a lt1 383 supercharged. And i have a canton pan. Which Oil pump should i buy. Its probably gonna be a melling so if you can suggest one of there oil pumps. Thanks
Old Feb 10, 2010 | 09:58 PM
Melling 10554. It should come with their pink spring for higher pressure.
Old Feb 10, 2010 | 10:03 PM
rskrause's Avatar
Moderator
No need for an HV pump and there are downsides.
Rich
Old Feb 11, 2010 | 12:39 PM
gillta95's Avatar
Using a Melling 10554 with stock pressure, in experience high pressure pumps have failures.
Old Feb 11, 2010 | 01:29 PM
Nahhhh. What is the reasoning behind your statement.
Old Feb 11, 2010 | 01:48 PM
MachinistOne's Avatar
Yeah...I'd like to hear this one too
Old Feb 12, 2010 | 01:32 PM
slingshot's Avatar
Having a high volume pump only is bad with a stock pan as it will suck it dry. I have a mellings 10552 which is 10 % higher volume, and it as been working fine with a canton pan. They did not have a 10554 in stock when I bought it, and I needed it same day. The volume it provides is pretty nice, it will start building pressure in the car as it cranks so oil is going through the motor before it starts.
Old Feb 12, 2010 | 08:02 PM
mrl510's Avatar
Thats what melling recommended to me was the 10552. So pretty much i need to choose between the 10552 and the 10554
Old Feb 13, 2010 | 09:38 AM
Gee... I didn't know that. I guess I better have them pull the 80psi spring out of the stock/blueprinted pump in my 800HP/800lb-ft 381 LT1..... its only been 10 years since it was built, and I'd hate to have "failures" now.
Old Feb 13, 2010 | 12:18 PM
94SLUG's Avatar
MAGIC
I have HV for 20k now, and many 120+ pulls no issues... When I asked my machine shop about this suck the pan dry idea they looked at me like I was crazy...
Old Feb 13, 2010 | 02:26 PM
RUDEDOG's Avatar
Same here. I never had a problem with the HV pump and stock pan. I tried to get it to suck the pan dry on a dyno and could'nt do it.
Old Feb 13, 2010 | 04:23 PM
Originally Posted by 94SLUG
MAGIC
There have been plenty of people post with issues and damage from an HV pump. Glad you guys are not having problems.
All it takes is a momentary loss of pressure at high RPMs to ruin your day.
Old Feb 13, 2010 | 09:42 PM
Bersaglieri's Avatar
I'll be running a High Pressure pump in my 383, we'll see if it poops the bed
-Dustin-
Old Feb 13, 2010 | 10:03 PM
grumpygreaseape's Avatar
MAGIC
call me old school, but if i recall correctly, the only gm motor that had an oiling system that could be "sucked dry" by a high volume oil pump was an oldsmobile motor.years ago i built a 403 in a 78 trans am and added rocket heads to it, ran it with a super t-10 i added. at the time when i built it, i called joe mondello (rip) and he said no hv pumps for olds motors. i have had hv pumps in all my sbc chevys-no problems
Old Feb 13, 2010 | 10:09 PM
mrl510's Avatar
im still undetermined whether to get a high pressure or high volume pump. Is there any positives or negetives on either one?
