Going thru used LT1 engine, what can I do to freshen it up?
Old Feb 15, 2010 | 10:40 PM
brandonppr's Avatar
I bought a wrecked LT1 96 ss Camaro. I will be putting it in my 3.8 vert. While I have the engine out, I want to go thru it and freshen it up.
I plan to pull the heads off and have them checked and a new set of head gaskets put on.
What else would you do while its out of the car?
I plan on doing new ignition parts and new gaskets.
Old Feb 16, 2010 | 06:06 AM
crash4cyl's Avatar
since it's out why not do a H/C swap and make a few more ponies? Won't cost too much more in the overall scheme of things.....
Old Feb 16, 2010 | 06:52 AM
koolaid_kid's Avatar
What are your hp goals for the engine? The pistons tend to be the weakest point, along with the rod bolts.
Old Feb 16, 2010 | 08:48 AM
brandonppr's Avatar
I don't want to go crazy with HP. I Just want something dependable and fun to drive. I have a LS1 car that is my fast car. This one I just want to be reliable and fun. Maybe a few bolt ons, but nothing too much.
Old Feb 16, 2010 | 09:55 AM
rskrause's Avatar
Moderator
I can't stand to take one apart w/o upgrading How about a little "pocket porting" on the heads? Seriously, though I would at least replace the valve seals and put a new set of springs and do a valve job on it if I were looking at the heads.
Am I correct you are not rebuilding the short block? That seems illogical to me - I would at least take it apart and make sure everything looks good and replace as needed. How many miles on it?
Rich
Old Feb 16, 2010 | 10:05 AM
sn8ke eatr's Avatar
summit sells a complete bottom end rebuild kit with forged pistons for under 700, you cant go wrong.
while everythings apart you should without a doubt put a cam in it. the hot cam kit comes with better springs and roller rockers. a hot cam will not give you every last possible hp but itll certainly help alot and you can be assured the kit is a quality one. the complete kit runs around 5-600 i believe.
now depending on your skillz you may wanna do a little gasket and port matchin on the heads; it really wont cost u anything
button that back up and you should have a nice 330-345 rwhp lt1 that will run for many years
Old Feb 16, 2010 | 10:27 AM
slomarao's Avatar
Rich
X2, i feel the same way. Why not throw a little money into the build if your going to go through the trouble of taking it all apart?
Rings, bearings, seals, vavle springs, timing chain, etc is what i would replace.
Old Feb 16, 2010 | 10:31 AM
I wouldn't write of the stock LT1 pistons, if it doesn't need to be bored. They are fine for up to 500HP, as long as you aren't running a power adder and exposing them to severe detonation. And you don't need forged pistons for a 330-345rwHP setup. A nice light set of hypereutectics is fine, as long as there is no nitrous or forced induction.
Old Feb 16, 2010 | 12:51 PM
ayers1967's Avatar
Just do the samething as the fast LS1 car .
Old Feb 16, 2010 | 12:53 PM
brandonppr's Avatar
What needs to be done to replace these parts?
I have never took anything apart past a shortblock.
In my LS1 car I have put in a shortblock, cam, timing chain, lifters, springs, rockers, and push rods. Nothing past that. That is also all I have done on the heads. I would like to learn to do the rest myself if its no harder than what I have done so far.
What is involved in relpacing the rings, bearings, and seals? Is there a guide to doing this on LT1s?
I was told that the engine was rebuilt 8k miles ago, but who knows if they were telling the truth. thats why I wanted to pull it apart and check everything. The car has like 160k or so on it.
Old Feb 16, 2010 | 02:27 PM
LT1 rebuild guide:
http://www.amazon.com/exec/obidos/AS...0target=_blank
Old Feb 16, 2010 | 07:37 PM
GhostZ28's Avatar
I just got myself a used unknown condition LT1 to swap into the 94 with milky oil. After I bolted it all up, i ran a can of seafoam into the intake via brake booster. After it shot bellowing clouds of black smoke out, I did plugs and wires, did another 1/2 can seafoam into oil and gas both, and soaked the fuel injectors.
idk, thats how I freshen up an engine, if I were you I wouldn't have even removed the heads unless it was having problems. I mean I KNOW its fun to take stuff apart but if its not broken and you arent planning on upgrading then let it be.
Old Feb 16, 2010 | 09:43 PM
brandonppr's Avatar
Maybe I will just replace the ignition and throw it in for now and pull it down later.
Old Feb 16, 2010 | 11:13 PM
GhostZ28's Avatar
yeah man, I recommend that. You'll be happier that you have it up and running quicker anyway.
Old Feb 16, 2010 | 11:50 PM
omgwtfdied's Avatar
Originally Posted by Injuneer
thats a great book too. I own it. Pretty step by step, with illustrations.
oldschool
Feb 9, 2016 09:21 PM
willismoons
Feb 14, 2015 08:42 PM
Jrlt1
Jan 3, 2015 07:38 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
