Exhuast HELP!!!
Old Feb 21, 2010 | 02:16 PM
jmac17's Avatar
Exhuast HELP!!!
I really want to run Dynomax bullets on my stock 1994 trans am but i dont know how i would do it with the stock cat back system. I want to get an exhaust in a couple of days but i NEED HELP!!!!
Old Feb 21, 2010 | 04:02 PM
If you want to put a pair of Dynomax bullet style mufflers on a stock cat-back, you would have to have a muffler shop run a splitter off the end of the intermediate pipe, and then route individual tail pipes to each side of the bumper, with the bullets in the individual tail pipes.
After you are all done, all you will have accomplished is changing the sound. To get any sort of HP increase, you need to do a full cat-back, with a 3" mandrel-bent intermediate pipe.
PS: Please don't post the same question on two forums... you already had this on the "Exhaust" forum.
Old Feb 21, 2010 | 04:47 PM
jmac17's Avatar
My bad, I didnt check this one before i saw the other one. And i posted it here because i thought i put it in the wrong area. My bad dude
Old Feb 21, 2010 | 04:49 PM
jmac17's Avatar
what do you mean by mandrel 3in pipe, because i was going to have the shop "redo" the stock system by increasesing the size to 3in instead of 2.5"(i think thats the size)
Old Feb 21, 2010 | 05:35 PM
The stock intermediate pipe is 2.75", but it is not the same diameter in all locations... there are places where it thins out to lesser diameter. A full 3" mandrel-bent pipe (no crimps) will flow better. All the quality aftermarket cat-back systems will have a mandrel-bent pipe. And a quality exhaust shop should have a mandrel bending machine for custom work.
Old Feb 21, 2010 | 05:40 PM
jmac17's Avatar
yeah the shop that im going to does have a mandrel to bend the pipes. Do you think ill have a "flow" problem with one pipe basically flowing straight out and the other one not getting enough flow.... if i decide to run two bullets . Also, would the bullets be visable from looking at the back of my car? Thanks for all of your help thus far!
ad356
Apr 11, 2015 08:49 AM
grgguy
17
Feb 23, 2015 07:57 PM
Goofy
Mar 17, 2003 01:00 PM
210Beast
Jan 27, 2003 07:34 PM
menlatin
N2O Tech
Sep 26, 2002 09:59 PM
