Header Swap - Final Parts List
I'm looking to order the rest of the parts for a Header Swap on my 1997 Camaro SS. Am I missing anything?
Here's what I have:
PaceSetter QuikTrip Long Tube Headers, ARMOR*Coat, Race Version
Custom ORY (From a '95 Z28 with Pacesetter LT's)
Fel-Pro #1406 Header Gaskets
!AIR/!EGR Blockoffs
Here's what I'm looking to order:
3/8-16in x 1" Percy's Split-Lock Header Bolts
2 24" o2 Extensions, Flat Connectors (Might pass on this and wire my own extensions using the Pacesetter kit)
Anything else? Tune will come in the near future. I have stuff for an oil change (I also need to delete my Oil Cooler). Planning on changing the o2's after the tune. Plugs/Wires are fairly new (~20k)
Going on a '97 SS. Car currently has Edelbrock TES Shortys, Stock Y-pipe, and the factory 2OTL catback.
Here's what I have:
!AIR/!EGR Blockoffs
Here's what i used
Pacesetter Lt's
Pacesetter y pipe
Mr Gasket - Copper Header Gaskets
ARP Header Bolts (Shouldve used the 1" which you can get from ARP i believe they are labelled as intake bolts... makes it way easier to get your bolts started while having clearance to make sure you dont cross thread your threads in the head)
new plugs
new wires
o2 extensions 12" and 24"
new o2 sensors
black zip ties (a must for your plug wires if your running them in the stock location unless you want to be replacing your wires all the time)
Use stock metal plug boots on # 5 and 6 cylinders to angle wires off the primary's
Lots of PB Blaster penetrating lube for the stock manifold and y pipe bolts
Lastly... lots of patience its not a fun job specially on the ground.
Any questions just about your install just ask...
Pacesetter Lt's
Pacesetter y pipe
new plugs
new wires
new o2 sensors
Here's what i used
Pacesetter Lt's
Pacesetter y pipe
new plugs
new wires
new o2 sensors
Pacesetter Lt's
Pacesetter y pipe
new plugs
new wires
new o2 sensors
)that came with the headers Just make sure to check/re-torque bolts after a couple heat cycles and a few times after that. It'll sound great thru the TOTL! I think mine does!!
I would never over the anything plug wires
Route them right and you'll be fine.
I have Breslin locking header bolts on my 94, but on my 95 I'm trying 6 point ARP's. The 12 point breslins were hard to use since you could only use close end wrenches and sockets.
I removed the manifolds and Y tonight. Broke all but 1 Y pipe bolt, but the manifold bolts werent too hard. All the manifold bolts except the rear two on the passenger are easy from the top.
Don't forget sparkplugs.
-Dustin-
Route them right and you'll be fine.I have Breslin locking header bolts on my 94, but on my 95 I'm trying 6 point ARP's. The 12 point breslins were hard to use since you could only use close end wrenches and sockets.
-Dustin-
-Dustin-
-Dustin-
I'm running the Breslin's too... They are the same as the Percy's.I plan on routing my plug wires, o2 wires, etc. with black zip ties so that's not an issue and I plan on picking up a can of pb blaster and soaking the y pipe/header bolts. Plugs/wires/o2's are okay and I plan on replacing them in another year or so.
Because you can get away without spending extra money on specialty long wires, looms, etc and just run them right the first time. Not to mention you have to screw with them to check or make any adjustments under your valve covers. All that hassle and money isn't worth it when it doesn't really keep you from burning anything. I also think they look God awful and clutter things up.
-Dustin-
-Dustin-
-Dustin-
-Dustin-
