PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Clutch master cylinder
  2. Spec Clutches and Chatter
  3. Stock Posi...
  4. What are needed to build Auto Trans?
  5. stall converter.
  6. lockup at w.o.t
  7. Swapping 6-spd into my 79 SE TA
  8. Slave Cylinder PROBLEMS...Please HELP
  9. new edge 3000 is in woo wee!!but have question on lock up?
  10. rear end help
  11. Which Trans is useful, ****auto or manual??
  12. rear axle oil? what brand you use
  13. 1999 Trans am tranny trouble
  14. quik help identifying my rear end
  15. uh uh uh another A4 bites the dust
  16. Strange Eng. U-joint question
  17. ? about Pinion Yoke and Safety Hubs
  18. Tech. Question
  19. richmond
  20. Flexplate for TH400 on LT1
  21. 3.90's now possible in a Moser 12bolt?
  22. BFG DR,+2800stall+mods=broke rear end?
  23. Auto tranny break in Question
  24. 3.42 or 3.73??
  25. T56 tranny
  26. Slave cylinder and lines
  27. Driveshaft Question
  28. differance between zo6 slave and fbody slave?
  29. 4:10's question
  30. How to take out pedals?
  31. Question on High stall (3000-3500) on Stock Heads/cam
  32. transmission swap
  33. Clutch Options
  34. How can i visualy tell if a 700R4 has a 'kickdown'?
  35. Cant figure out what year my tranny is....but i have the numbers i found on it...
  36. Did i break my T-56 or my Clutch?
  37. stall Torque converter question
  38. Need to Re-tune after Higher Stall TC??
  39. transmission problems (I know this is probably getting old)
  40. Cheap clutch Ideas
  41. Mcleod clutch install
  42. Replacing torque converter
  43. Anyone ever build a budget 9 inch?
  44. 4L60E 3rd gear confused..
  45. Valeo cltuch disk oem?
  46. Trans leaking
  47. What does re-stall mean?
  48. Grinding problems w/ tranny after autocross!
  49. Extreme Problem: Cross Threaded/Stripped Bolt in Rear
  50. Exploring new clutch and flywheel options
  51. installed 10 bolt 4:10 rear-end need help ?
  52. Tranny acts wierd after peel out.
  53. Need some help with trans!
  54. lost 3rd and 4th gear
  55. gears for a 6-speed
  56. Rear end swap
  57. 94 4l60e tranny questions
  58. What did I mess up... clutch not engaing
  59. What Gears Do I need?
  60. Please Help: Moser 12 bolt leaking at the brake disk. Seals hard to replace?
  61. Gear Whine On Acceleration
  62. which 12 bolt should i get?
  63. dodge viper transmission in LT1
  64. Help! - New gears now my speedo is freakin out!
  65. Suggest a converter
  66. i need a new carrier
  67. Automatic tranny question
  68. How does trans know when to shift?
  69. HELP!!!! Shifting and lose problem with my T56
  70. 83 Z28 Transmission
  71. anyone ever open up a T56
  72. Is my posi shot?
  73. how to determine the type of my rearend
  74. gears and how long will 10 bolt last?
  75. Adding fluid to an m6
  76. Rear Gear Help!!!
  77. 3.73 gears...
  78. What Gains Can Be Had By Going With A 3000 Lockup Stall With 3 Disk
  79. putting in rear gears
  80. 83 Z28 Rear End
  81. diff. between 3rd gen v8 and 4th gen v6 T-5s
  82. Anything needed to do to a street twin before installing?
  83. TCI, SLP or B&M CONVERTER??? HeLp
  84. CANT GET AXLE OUT..MOser 12 bolt
  85. Difference between 95 4L60E dust cover and 96-97 steel one?
  86. ABS ring reluctor
  87. bad vibration
  88. Going after my pilot bushing this weekend, what else to look for?
  89. Need HELP! cruise control problems.
  90. Difficulty of installing 3.73
  91. wtf is dextron II E?
  92. Driveshaft Question
  93. tranny rebuild
  94. What's involved to swap in a 95+ 4L60E into a 94 F-Body?
  95. gm poly tranny mount
  96. Need your honest opinions
  97. Gears for Manuals
  98. 4L60E w/4600UY or TH400 w/4600&T-brake?
  99. Possible rearend problems with LCA relocators & eibach sportlines?
  100. Clutch fork bolt size
  101. Shifter for 4L60E??
  102. Master to Slave Cylinder Line HELP ASAP :)
  103. What should I do
  104. Shift Kit
  105. grinding again
  106. 12 pin or 13 pin
  107. How much does a stock 10 bolt weigh?
  108. Strange 12 bolt - check fluid level?
  109. In car video
  110. harsh shift
  111. How much to install 3.73 gears?
  112. Transmission
  113. a-4 to m-6 guys come inside
  114. Part # for LS1 Tranny mount that will fit LT1s?
  115. Clutch Grip with deeper gears
  116. Moser 12 bolt Price and info HELP
  117. 4.11s Without Recalibration (Temporary)
  118. stall converter concerns??
  119. !!! I Love My New Ripper !!!
  120. what will be the best for me?
  121. 2.73 in LS1 Z28?
  122. are my synchros gone?
  123. horse power loss
  124. 3.73 M6 guy's, what are you shift points?
  125. Do It Yourself Gear intall
  126. Need help quick - Transmission line pressure?
  127. 9 bolt strength
  128. west coast coverters or edge???
  129. Pinion gear nut
  130. poly trans mount...
  131. m-6
  132. 01+ MC work on '94 lt1
  133. removable bellhousing
  134. 4L60E On a 1996 3800 v6. Where to get a new one?
  135. Gear grinding problem???
  136. need 10 max power advice..help
  137. Where in or near Ohio to get m6 swap done
  138. how do u lock up your converter on a dyno
  139. next best thing to vigilante???any converters come close??
  140. rims
  141. Will I break my 10 bolt?
  142. 700r4 Transmission Information.
  143. OK I need help, manual transmission swap-interested
  144. Adjusting the clutch???
  145. Gears, differential install
  146. The right gear for me?
  147. Clutch sticking...
  148. how long does it take the 4l60e to shift
  149. 4L60E Interchangability
  150. How toast is my clutch?
  151. drivetrain still missing something
  152. clutch slave cylinder question
  153. how many miles for a street twin breakin?
  154. Tranny issues?
  155. Gear Pinion Spacer
  156. vig 3200 any transmission mods????
  157. How hard to change output shaft (T-56)
  158. possible to breake 10 bolt on the street with Drag Radials???
  159. 6-speed manual to TH350 conversion
  160. reccomendations,resources on T56 clutch install? Syncro
  161. Clutch fork inserted
  162. Whats wrong with tranny?
  163. T56 needs 1-2 syncro, shoud i buy it?
  164. Rattling noise in neutral, in an M6
  165. 4th gen rear width vs 3rd gen width,hurry
  166. 4.10 10 bolt for sale
  167. Will a Spec Stage 2 be enough?
  168. 12 bolt prices
  169. Clutch choices
  170. t56 rebuild difficulty
  171. Yet another tranny thread :)
  172. WTF, I really need help with my trans
  173. Clutch pedal squeaks
  174. LT1 TH350 guys
  175. WTB 8.2" posi carrier for 70 camaro
  176. Very happy with LUK Pro Gold
  177. Clutch fork spring clip
  178. T-56 Clunking noise
  179. transgo shift kits.
  180. Short Shifter Install? (nOOB)
  181. Is there something wrong with my rear end?
  182. Metal buzzing sound under the car, 2000 trans am
  183. ? about t56 swap
  184. Bad clutch or synchros?
  185. 460LE hesitating/hitting limiter?
  186. Narrowed rearend
  187. Installing new gears
  188. Polyurethane Transmission Mount?
  189. Flywheel Resurfacing
  190. transmission mounts?
  191. what clutch are u 6 speed guys using to handle 650-700 hp? i need help
  192. T-56 Rebuild Question
  193. 4L60E converter and coast problems
  194. Will a 95 Impala SS 4L60e fit in a 94 Z28?
  195. torque convertor for 411 gears
  196. The Whine that never leaves!!!!!!!
  197. 93 A4 to 94+ M6 conversion
  198. Will i break my 10 bolt?
  199. HELP FAST easy stall questoin!!!
  200. Rearend gears, differential pricing
  201. 12 bolt leaking
  202. Steel or aluminum driveshaft
  203. Metallic vibration/rattle at 2K rpm after new clutch and T56 rebuild
  204. A few questions on the Mcleod Street Twin
  205. th350 question
  206. Do I need the paddle kit?
  207. which rear end,need honest answers
  208. Clutches
  209. 4.10 in a a4
  210. Need to find good manual trans shop in So Cal area.
  211. 700r4 swap, electrical connections???
  212. Powertrax Posi Question
  213. Can I fill up the tranny where the shifter bolts up to?
  214. Can you change the gears inside a T56 ?
  215. Where to buy LS6 clutch?
  216. D&D 30spline T56 in FS section
  217. Problems with A4 and boost. Please help.
  218. Anyone ever put 4 channel axles (reluctors on each end) in a 3 channel rear end?
  219. LT1/T56 Flywheel balance
  220. Which would be cheaper
  221. anyone have a SPEC stage V?
  222. Broken Slave cylinder
  223. Flp 4l65e
  224. 700R4 Speed Sensor
  225. Will my rear be ok?
  226. torque converter question?
  227. thickness of ring gear for a 3-series carrier?
  228. Swapping Out Trannys to a T56 Questions.
  229. Clutch Pedal Dropped to Floor
  230. drivetrain loss question...
  231. Torque Converter
  232. Tranny Rebuild
  233. 700R4 Self rebuild
  234. automatic to manual swap
  235. A4 grinding noise while driving
  236. 3.73 or 4.11 for my 6 speed?
  237. driveshaft issue
  238. How do I install trans cooler on 95 Camaro?
  239. TH350 Question
  240. U-joints, which one to change?
  241. is this a spec stage4 for lt1 ?
  242. Clutch Problems
  243. bushing / bearing in the tailshaft of T56?
  244. Clicking noise coming from under console area......
  245. anyone know thread size on stock t-5 shifter?
  246. Average life on A4 tranny's on LT1's everyone w/experience post inside!
  247. difference between m6 and a4 crossmember
  248. MOSER Gears
  249. ever hear of Mad Dog transmitions?
  250. S10 TQ convertor mod...
