View Full Version : Drivetrain
- Flexplate - 168 to 153 ?
- What torque converter to get?
- Noise from rearend after new wheels. ???
- Will an LT1 t56 bolt up to a LS1 block
- Weird clutch
- clucth problem
- T56 Borg Warner Tranny rebuild
- what happens
- losing power with a 9 inch?
- Which flexplate do I need?
- installing a Moser 12 bolt in a LS1?
- 4.10 LS1 vs 3.42 LT1 for off idle torque
- Wich car had TH350 trannys?
- LS1 vs. LT1 spec disk
- noise from the new 12 bolt
- Vigilante 3000 Stall
- Vibration RPM on park or neutral A4
- vibration on Decelleration!
- 350 turbo transmission
- Clutch feels like a four letter word that starts with 's'
- Midwest stall
- spider gears
- What is a torque converter?
- How my tranny fluid in torque converter??
- cost question
- tci vs. midwest (converters)
- now what 12 bolt is in
- 4L60e Trans
- hard to shift
- Gear lube question
- SPEC stage III clutch and Billet Flywheel came in!
- Is my new converter behaving normally?
- Need to shorten driveshaft with a Moser 12 bolt?
- tranny fluid
- Broke my converter or my tranny?
- 28 spline moser axles
- Nitto Drag Radials on a stock LS1 Z
- B&M Shift improver kit
- U.S. gear any good???
- Where to buy Lou's Short Stick?
- Quick question on shift kit
- 4L60E Garbage????
- DTC 28 trany code
- Any truth to the statement that all Richmond's hum in 10 bolts?
- Which High Performance disc with stock pressure plate?
- What size stall can I run on street tires with 3:23's?
- Part Number Please
- trany swap
- bolt in or weld in lca relocation brackets
- Torsen rear end help
- clutch
- Does a A4 Tranny from a LT1 bolt up to a LS1?
- How to go about putting in a short stick shifter?
- replacing axle studs on stock 10 bolt
- Snapped driveshaft in half!
- noise from rear end or what?
- Which SPEC clutch is better?
- Best brand of TC...
- bolt in side of transmission
- broke the carrier bearing race in the 8.5" 10 bolt!!
- Is there a difference...
- What spline is in the fourth gen rearend??
- midwest 3400 stall
- Will a Vigilante from a 95' A4 fit my 00' LS1 A4 ?
- Serious Problem!!
- trans prob fixed?
- 12 bolt axle length...
- solid shifting
- All short sticks the same??
- how do I remove U-Joints?
- spool?
- Moser 9" rear end and LPE driveshaft
- to my v8 boys ,hows your rear doing
- all you A4 guys?!?!
- 2.73 to 3.73 swap
- do 3:73 give you better pull on higher speeds too?
- A4 mis-shift?
- URGENT Will this fit my car?
- URGENT--Will this fit my car?
- Torque Arm Question
- Clutch Replacement
- Some ???'s on Torque Converters
- Moser 12 bolt - Pinion Seal/Bearing Replacement Question
- could changing a u joint the wrong way kill a 10 bolt?
- Replace my 4l60e for 700r4?
- Very weird tarnny prob inside...
- Rear Axel Leak 2000 TA ? Pinion ?
- Rear end gears question
- What's wrong with my rear end??
- Should I upgrade my hydraulics?
- Gearvendor question?
- Stock pinion angle needed
- do manuals have cruise?
- Rear end Posi failing, or is it just me?
- 10 Bolt 3.90?
- What size stall should I get?
- Runnign 33 spline axles cut down to 30s in 12 bolt
- transmission or clutch?
- URGENT: Adjusting TV cable... what button?
- break in for a spec 4?
- Any one ever deal with Carolina Clutch and Performance??
- MEssed up
- Fluid Capacity?
- Problem with false knock due to shifting. Please help.
- 96 z28 wont take second
- Pilot Bushing or Bearing?
- tranny help
- TC or Tranny Problem?????
- Billet Flywheel
- McLeod Street Twin-plz help
- What Year/gen T56 Was The Strongest??
- Will TH350 bellhousing bolt work with a 4L60E?
- Rearend Swap
- TC problems above 3000
- Str????
- 98 up Moser 12 Bolt in a 97
- McLeod street twin: counter-weight/balancing question
- Just ordered SPEC stage III and bullit steel flywheel
- Netgearhead Tranny's...What have you heard?
- could it be my tranny?
- those with HOME MADE 8.8 rears in your lt1...
- Changing from 2:73 to 3:42 or 73
- t56 rebuild
- 4l60e rebuild?
- Swaped tq converter, few q's
- Slipping clutch? Vibration?
- Which clutch?
- Clutch install re: disconnect master cyclinder?
- Stock rear-end?
- transmission tragedy update - A4 guys inside please!
- Which tranny fluid and how much?
- How hard to remove rear end
- Anchor Tranny mount
- 4l60e to TH350
- can i replace my 7.5 rear with 8.5?
- 4l60e to TH350
- Time for a tranny rebuild
- Synchro ?
- Which Clutch Do You Recommand?
- Problem w/ 2nd Gear (t-56)
- 4L60E trans problem!
- Not letting me shift into gear
- Valeo? Please read RE: Clutches
- Strange or Moser 12-Bolt
- Lot of questions about a Stall converter!
- tranny help please
- tranny puzzle
- prob with camaro? need help tonight plz
- Why doesn't motive engrave the backlash?
- Clutch disc swap?
- Anyone know the length of a stock Driveshaft?
- clutch question
- T-56 Problems?
- What paint do you use on a rear?
- What u-joint do I need to mate my 1le DS to an 8.8 ford??
- torque arm bushing please help!!!!!!
- T56 syncros
- Opinions and Facts on Tranny's for a Swap
- grrrrrr 700r4 swap done, won't shift at WOT
- Lost all my tranny fluid, car wouldn't move, came home on a flatbed.. a few ?'s.
- Shaking?!?
- Strange Engineering trans yoke / stock driveshaft u joint ??
- 95 auto trans problem
- quality/stregnth of B&M torkmaster converters???
- pedal stuck to floor in three
- 10 bolt and 12 bolt
- Cant get 3rd in correctly
- Simple Question......
- Transmission Codes
- Rearend Noise
- T56 input shaft and pilot bearing cleance ?
- How to tell if clutch is aftermarket?
- Moser 12 Bolt - Gear Whine Normal???
- 4l60e Trans 1,2, and 3,4, nothing
- manual for rebuilding a 1994 T-56 transmission
- Clutch turbo transmissions
- Flexplate question
- Tranny PWM sol question
- Strengthening the 10-bolt: worth it or no?
- flexplate? 153 tooth external balance?
- transmission...what could it be?
- LS1 Drivetrain Books
- auto tranny and rear be able to hold almost 400 HP and TQ?
- bad viberation after replacing tranny mount!
- Shifters, Hurst or Pro 5.0?
- T56 Troubles.....
- Rear End Swap Question
- 10 bolt
- driveline (possible T56) problems.....long
- Manually downshifting?
- strut cartridges
- What all is need for a A4 to M6 swap?
- Tranny burned up again, 8th time.
- Which gears work best behind a M6?
- 2.73 conversion needs new posi unit??
- clutch pedal assembly removal
- Help on my clutch
- What stall to get?
- TH350 Need help with some info, 95 LT1 ---Speedo & Flexplate & Transbrake
- Am I stepping in baby food?
- Tranny won't shift well.
- Need some trans wiring help m6 to auto
- Who has the best deal for a Pro 5.0 Shifter for a 95 T-56?
- Torsen and Limited slip differentials
- Weird tranny problem a4
- Speedo Gear, or Re-code??
- valve body diagram???
- clutch problems
- CLUTCH WRITE UP (Stock, SPEC, Centerforce)
- clunk when stopping
- Body Sag
- trans question?
- Solid pinion spacer Setup
- Is my Tranny or Clutch going out?
- BMR Tq Arms
- Too many tranny coolers to choose from
- HELP Th350 speedo
- how do these line up?
- Aftermarket suspension products
- Looking for rear end replacement ideas. Give me your input...
- clutch master cylinder help!!!!!!!!
- 3rd gen and 4th gen diff's interchangeable?
- Attempting diff exchange
- typical cost of syncro replacement?
- Anyone use ring gear spacers?
- Blown rear
- Auto or Manual?
- What does a torque converter do?
- Strange noise coming from transmission - help!
- th400 swap TCC ? 93 TA
- T56 Clutch not disengaging?
- gears
- What oil for stock rear/posi? Syn./non-Syn. Additives?
- transmission temp guage
- M6 tranny makes clicking noise when cold
- Broke Pinion Shaft Retaining Bolt in carrier! Now What?
- Clutch won't disengage when running?
- best for Hight HP 10 bolt?
- Should I replace or Reuse Ladies and Gents?
- A4 Problem 2nd and 4th gear band breaking
- Moser 12bolts......
- Why isn't my street twin disengaging??
- ..Pinion seal leaking, only when driving..
- 3 or 4 channel ABS
- What was the deciding factor
- Torque conveter lock up Q?
- Pinion nut torque specs?
- Another Torque Converter Brand Q for drag
- Can old fluid cause a Auto not to shift at correct points?
- Weak Trans and 3200 stall??
