PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Anyone have a problem with driveshaft in a t-56 swap in a 3rd gen
  2. Speedometer off with 4.10's???
  3. installed posi. whats this nosie?
  4. how do i bleed ls1 slave????
  5. somethings not right!!!
  6. 3.73 or 4.11
  7. terrible clunk need help please
  8. Bad Engine or Tranny Mounts??
  9. did i buy the right shift kit
  10. Axle switched?
  11. 95 LT1, T56 makes noise when "unloaded"?
  12. is this my bearing?
  13. 8.8 ford conversion questions (in process)
  14. Excessive rear end noise
  15. F-Body Rear Ends
  16. what clutch for 350RWHP &350RWTQ???
  17. Installing Pilot bearing
  18. HELP! Trans won't stay in park
  19. Slight surge/jerk..
  20. Transmission shop in B'Ham, AL?
  21. Aftermarket shifter for 4l60e?
  22. What stock gears does my car have?
  23. Cheap converter for a 4L60E +N2O?
  24. Should I change my tranny fluid myself or get it flushed?
  25. Do i have a short shifter???
  26. Ring and Pinion Install Question
  27. What driveshaft do I have?
  28. T56 fluid capacity?
  29. "Genuine" Gears?
  30. 94 T/A, how many spline axles?
  31. Slight Bumping/Poping under driver side floor board under load...
  32. HELP --> Very bad vibration with LT1 M6
  33. how big of a difference will i feel?
  34. help me with my trans build
  35. rear end oil change how much do i need to put?
  36. Clutch Chatter Help
  37. New tranny or rebuild?
  38. Is this true?
  39. ...Another 3.73/4.11 Question
  40. 31 spline axles ok?
  41. Where to get a Tranny Cooler?
  42. Bad throwout bearing? Ram clutch kit?
  43. transmission mount
  44. Viper 6spd in an IROC
  45. stall? buying this friday
  46. 4.10 gears.. any makes to avoid?
  47. Slave Cylinder pushrod bent??
  48. Corvette Servo in 700r
  49. deep screeching sounds?
  50. Need help with stall converter!!!!!
  51. Is a pro shifted t-56 any different that a shift kitted auto?
  52. Grind in 5th and 6th
  53. 4L60 weight
  54. Finally came out of denial
  55. Viper guy here in need of help with his T-56!
  56. BMR relocation bracket help.
  57. 2800 stall already, upgrade to 3200 or 3400?
  58. Yet another humming F-Body!!
  59. Spec stage 4 from lmperformance?
  60. G E A R S..
  61. Crush collar or solid spacer
  62. 4l60e swap to Manual tranny?
  63. Need trans help bad(T56)
  64. went to track, now weird noise? help please!!
  65. rearend noise Please help
  66. Clutch grabbing high up after not driving car for over 1 month
  67. 12 bolt ??
  68. pros/cons 4.10 gears
  69. 383 flywheel???
  70. Need help getting car into neutral
  71. A4 clunks into 2nd
  72. Strange 12-bolt question
  73. Anyone know of any SPEC sales going on?
  74. Rachet Shifter for 4th Gen. Z28
  75. Trans-GO shift kit
  76. shift jump
  77. vig part number
  78. Aluminum Driveshaft
  79. Something you should know about SPEC
  80. Who has taken out their poly trans, or torque arm mount because you didn't like it?
  81. Clutch Hydraulics
  82. T56 swap for a Cleveland.
  83. 2000 Z28 3.42 in a 96Z28
  84. scatter shield
  85. what are the TQ specs for the LT1-T56 clutch bolts?
  86. Rear End Fluid
  87. Drilling Slave Cylinder
  88. For Knowlegable tranny builders/gurus only.
  89. Gears
  90. slave cylinder rod stuck. need advise
  91. quality of superior gears
  92. Which ARP bolts for 4L60E converter
  93. quality of superior gears?
  94. Torsen dif isn't getting power to both wheels
  95. Hard to get out of 4th (M6)
  96. Which tranny shop to go with????
  97. Problems with SLP Clutch PP Set
  98. tranny slipping
  99. Tranny probs still....i'm out of ideas....i'm gonna push my car in the river
  100. High Stall torque converter???
  101. need info
  102. what do you think?
  103. OBD1..can I run a 3000+ stall?? Whats the odds
  104. 8.5 in S10?
  105. posi
  106. rear end
  107. Stock Flywheel with SPEC Clutch
  108. FYI---> Energy Suspension
  109. Slave Cylinder
  110. Dealership re-calibrate speed-o?
  111. want to put posi in my car
  112. Shifting hard into 2nd gear
  113. Tailshaft bushing on a 4L60E
  114. 4L60E Line Pressure question
  115. Mind game or other 9" owners
  116. clutch hydraulics ?
  117. Hurst Billet Plus shifter and question needing verification.
  118. Need help
  119. changing the throw out bearing? how hard/long?
  120. worried about my transmition
  121. Help me decide on rear.....
  122. those with 9"ford in fourth gen in here
  123. 2800 stall with 2.73
  124. Converter Comes Unlocked...
  125. $
  126. No OD after Transgo install? Anyone have this happen?
  127. Help with my 4L60E upgrade
  128. Driveability Issues... Need a resolution.
  129. Feeling slow from a stop
  130. How does this sound for a stronger stock rear end?
  131. Which Shifter?
  132. need responce asap
  133. Is This Spec Clutch Right For Me?
  134. tranny swap
  135. transmission magnets??
  136. Gearbox Mystery!
  137. slave cylinder rod hanging out??
  138. 4L65 rebuilt kit
  139. A4 Bellhousing bolt sizes?
  140. bellhousing stuck? what do to?
  141. loud whine from rear
  142. just changed my rear differential fluid
  143. SOLID T-56 Tranny Mount ????????
  144. Replaced tranny mount......now what?
  145. Howl after gear change
  146. installed rear end..BIG PROB. PLZ HELP!!
  147. Bleeding clutch hydraulics. . .
  148. swapping from a a4 to a t56 in a ls1 car
  149. My rearend just got owned by my Street Twin... on stock tires???
  150. What is the minimum speed you should cruise in 6th gear?
  151. 4L60E Transmission Line Pressure Plug
  152. T56 Tube on Top of Trans?
  153. No gears in 700R4
  154. Clutch slip?
  155. Need Help Now!
  156. Corvette torque converter...
  157. 4.10's and RPM's at the end of the 1/4
  158. stall converters
  159. big trouble! clunking noise when I get on it....
  160. Manual Shift Auto
  161. HELP!!! No OD, slipping 2nd
  162. 3rd gen rear ends
  163. Vibration, and nasty noise? Any thoughts?
  164. how many shift solenoids in the automatic
  165. SPEC stage 4 clutch slipping??????
  166. Tranny cooling line bolt size??
  167. clutch chatters badly, barely get car moving
  168. th350
  169. how to change axles on 01 SS
  170. Need input shaft seal help
  171. 4.10's and tire size PLEASE!!!!!
  172. help. need LT1 4L60E valve body rebuild guide
  173. axle removal
  174. T56 conversion... need 12V switched power for !CAGS
  175. Wierd Problem with my 4L60
  176. high stall TC w\o head\cam
  177. Re-build or buy a new one????
  178. What should my Shift Points be?
  179. Kids, behave while I am away (or else)
  180. Fluid Capacity of Stock Rear Axle?
  181. Only 1st and 3rd Gear
  182. aluminum driveshaft
  183. Is 3500 to high...
  184. Moser is in...
  185. Gear slap?
  186. No more Posi
  187. tire size?
  188. Servo Questions
  189. Best Shift Kit?
  190. Replace pilot bushing?
  191. Got the A4 out of my car, got Q about speed sensor...
  192. vss and turbo 350?
  193. small bolt pattern flexplate
  194. Overbuilding for Reliability
  195. What can it be
  196. how long from first rear end noises to rear end explosion?
  197. Lost ALL gears in transmission
  198. Questions about gear installation
  199. 4.11's
  200. 12 bolt moser HELP!!
  201. slippin' ???????
  202. clutch problem that has me stumped
  203. how to tell if a tranny is slipping?
  204. Mcleod Street Twin vs. Spec Stage V
  205. So which gears do I have???
  206. electrical connector on top of 700r4 tranny
  207. need fast help about pilot bearing install
  208. grinding in torque converter????
  209. Got 250 bux. NEED TORQUE CONVERTER
  210. Extremely quick A4 question...(need answer today)
  211. Bearing Races in Rear End
  212. Auto VS Manual clutches
  213. removing tranny?
  214. shifter console mod, a4 to m6
  215. gains with stall
  216. ----------------Strange gears ---------------
  217. change 2 series to 3 series
  218. Driveline Clunk.. Driveshaft?
  219. tranny problem or what?
  220. Trans linkage off?
  221. 4L60E line pressure specs i set
  222. NEED HELP FAST (best combo)
  223. is this a good product?????
  224. Strange gears
  225. 12 Bolt or 9"
  226. Driveshaft Vibrations?
  227. T56 Question.
  228. My last trans question for the day
  229. Who has wrecked tranny with hpp shift firmness.
  230. Dual tranny coolers?
  231. shift kit gurus....quick question on the one I just got?
  232. what series carrier is in a 2.73 rear end
  233. How long will the A4 trans last?
  234. Weird problem with Slave cylinder...hose won't lock in
  235. 4.10 owners 1/4 mile times.
  236. Any 4th gens come W/OUT a damper on the drive shaft yoke?
  237. Didn't get the clutch fork engaged before bolting it all back up...
  238. How safe is a used set of gears?
  239. How much fluid is needed for tq conv. and shift kit install?
  240. Rattling noise from tranny?
  241. signals of broken tranny mount?
  242. Hot trans
  243. Rear and Trans oil
  244. Whats the diff? SPEC Star Clutch and just spec clutch
  245. Ford 9" rearend switch???
  246. what do i need to make a 700r4 work
  247. I hered a GRINGING NOISE. Now its CLACKING BAD in Rear END. NEED Help?
  248. how to tell what gear I have?
  249. 4.10's and 10 bolt
  250. installing clutch fork with tranny bolted up
