PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. What broke in your 4L60E?
  2. 4l60e swap time
  3. No 2nd gear (M6)
  4. How to tell the condition of a m6?
  5. changing fluid in an 00 m6, how about a synthetic fluid?
  6. driveshaft question
  7. 10 bolt girdle stud preload.....
  8. 90 or 120 weight gear oil in rearend.......
  9. I need T56 pigtails(Connectors)
  10. Changing rear end fluid
  11. U joint part number needed for lt1 1350 yoke
  12. Stock 10 Bolt and LE1, Will it hold?
  13. 3.73's for C6's
  14. 3.42's or 3.73's
  15. How to store a 10-bolt?
  16. mechanical speedo to electic
  17. Trans crossmember
  18. Auto guys w/3.73s inside...
  19. Driveshaft length: Moser 12 bolt/9"
  20. Weight diff. 12 bolt vs. 9" ?
  21. Fuddle Racing is here!
  22. $50 off the market's best Torque Converters
  23. Too Good to be True?
  24. 12 bolt pricing?
  25. M6 ugraded clutch and internals?
  26. How much HP/TQ can a 97 T56 Handle?
  27. Can't remove T56... it's not the clutch fork...
  28. Where to get some gears?
  29. Tranny Swap - 1996 M6 and 1994 A4 - Issues?
  30. TA parts compatible with Camaro?
  31. Clutch Want Disengage
  32. Another clunk problem!
  33. How long did your 4.10's last and what brand did you get?
  34. Advantage of 4.10 gears?
  35. stock converter stall speed in z28?
  36. 9in rearend help
  37. Problem with Clutch/Tranny
  38. Pinion Bearing
  39. Plug for CPT
  40. Need help w. gear installation!
  41. T56 Shimming
  42. Rebuilding transmissions
  43. Power Grip HD review!
  44. Clutch #4
  45. clutch hydraulics?
  46. t-56 will not shift into reverse unless key is on - normal?
  47. T56 Swap Question
  48. Tell me about these "updates" from Pro-Built.
  49. What plate do people refer to on a energy suspension tranny mount?
  50. bad slave cylinder symptoms
  51. Damnit, another clunk thread...and its not the trans mount
  52. bent shift fork or what?????
  53. Where can i find Precision Gears?
  54. slave pushrod plastic cup question
  55. Buying Torque Converter
  56. Noise when coming to a stop
  57. Anyone running a Lt1 with Ls1 Trans Mount?
  58. Need torque specs ASAP!!!!!!!!!
  59. 10 bolt question: believing all the hype?
  60. Should I get 10 bolt girdle cover?
  61. New Ram HDX Clutch and I'm not happy
  62. Rear end question
  63. Which Clutch is better...LUK or Valeo??
  64. Reverse in T56 popping out
  65. help with setting up mcleod clutch
  66. ford 9" and TCS
  67. 4L60E GM truck pan part #?
  68. Gear problem?
  69. whats a good trans mount??
  70. Squeak from rear end
  71. Trans leak
  72. 4l60e Help???
  73. anyone have measurements of rear?
  74. Need help with 4L60E breaking the pump shaft!!!
  75. 4l60e ?
  76. Rear end making extremly loud humming sound, plz help
  77. Help me choose a new rear
  78. Rear End Problems
  79. Corvette Servo
  80. help with mcleod street twin
  81. What Diff. fluid do I need for my new gears?
  82. vibrating at speed, feels like bad u-joint, but
  83. changing gears - 308 - 373
  84. T-56 problem
  85. T-56 problem
  86. Rear end options and prices...
  87. T-56 Question
  88. What gears for 95'Z 6 spd?
  89. Servo Question
  90. Axle shaft seals
  91. old school 12 bolt
  92. HELP PLEASE! Clutch Pedal Stuck To The Floor Today
  93. 1996 T56 Clutch Hydrolic line
  94. Estimate Cost of Clutch Replacement?
  95. Strange 12 Bolt Fluid Replacement
  96. Possible to put a LS7 clutch in a LT1 car?
  97. How do you remove slip yoke off of aluminum drivesahft?
  98. T56 replacement parts
  99. Gear Choice for 94 Z28
  100. torque converter stall speed
  101. Best clutch for the $$ 96 LT1 M56 head/cam/header swap---
  102. Rattling noise in 4th and 5th gear. Will not go into Reverse.
  103. 410's in auto with ls1 power
  104. 1st gear block in 3.4???????
  105. Strange 12bolt
  106. car shaking like crazy help!!!
  107. six speed M6 shift knob part number....
  108. T56 getting hard to shift....
  109. Rear wheels locked up
  110. Ideas for Rear End Fabrication
  111. 4:10 brands?
  112. Cpt
  113. where to jack to get tranny up
  114. Pro's and Con's to Trans Break
  115. differential leak?
  116. My work (dealership) said I have to get a new differential for gears
  117. Is my clutch ruined?
  118. 6speed woes!!!! help...
  119. HoW to CHanGe traNNy FluiD????
  120. broke bellhousing on v-6
  121. Lockup Converters
  122. CAnT figure THis OUt!!!!!
  123. Car is hard to get into reverse
  124. vig converter in 97 camaro?
  125. No 3rd Or Od-
  126. Fidanza Aluminum Flywheel Part Number?
  127. Is there a reason GM blocked 1st for 2.73 cars?
  128. I'm in the mood to write, need drivetrain topic suggestions
  129. Holes wont line up for LS? HELP ME
  130. Overdirve gear ratio
  131. 2.73 or 3.23
  132. what can i do with 250 dollars?
  133. Check out the pics of my input shaft & TOB...
  134. anyone ever shorten their rearend a little bit
  135. Will an 1998 LS1 rear end fit my 1996 z28?
  136. Difference in 2 series and 3 series gears?
  137. Clutch Problem?
  138. Torque converter, lock up questions
  139. Thoughts on the Centerforce DFX
  140. Why are stock rear axles so weak?
  141. Trans Swap
  142. Ebay short shifter??
  143. t56 hydrolic help asap
  144. Clutch Going?
  145. Vibrating Mount
  146. Question about stock tanny pan on a 4L60E.
  147. B&M shift improver kit??
  148. So, gears or not???
  149. T-5 problems no reverse
  150. McLeod Adjustable Master Cylinder
  151. New A6 transmission
  152. Rear end mods?
  153. high stall question
  154. Where to buy/repair 4L60E?
  155. hard clutch pedal
  156. t56 need help
  157. SPEC Stage III
  158. Auto to Manual conversion
  159. I'm desperate for a rearend!
  160. Holding 1st until 4000?
  161. Noisy rear?
  162. LT1 T56 dust cover/inspection shield?
  163. 6L80E 6spd Auto
  164. Tranny Issues
  165. Broke a Tranny Mount!!
  166. Pro 5.0 shifter
  167. Flywheel help
  168. Extremely stiff pedal, need help ASAP please
  169. Which clutch for my application?
  170. Reusing diff and tranny fluid?
  171. Why you should Kare about "K" (the truth about stall speed)
  172. Trans Break?
  173. TH-400 reluctor ring removal ???
  174. All M6 FLywheels equal?
  175. Update on my issues, and a question...
  176. T56 Torque Arm Mounts all the same?
  177. 4L60E Shift Kit vs PCM Tune
  178. rear end swap ?
  179. 4l80e
  180. Limited Slip for my broke 9"
  181. Engine Swap
  182. how much fluid does a 700r4 take
  183. TH-350 question
  184. 6 speed Conversion-Computer?
  185. Hot spots on the flywheel??? Junk???
  186. tci tcu unit
  187. Look whats left of my clutch
  188. a4 to m6 conversion. where to start
  189. Anyone know of an good transmission additives?
  190. t-56 get stuck in reverse when shifter is in neutral?!
  191. clutch not fully releasing?
  192. Transmission replacement
  193. th400 w/ Turbocharger
  194. 12-bolt doesn't fit...need immediate help.
  195. Noise after street twin rebuild
  196. Need info on 4.10's
  197. Tranny mount part #
  198. Did your torque converter kill gas mileage?
  199. Tranny fluid change
  200. Will transgoshiftkit for my lt1 fit a 99 ls1?
  201. 94 z28 automatic trany problems
  202. What is the ideal transmission cooler for our cars?
  203. Can a bad Torque Converter cause eratic Idle?
  204. Help me out here, can't get the driveshaft out...(not as simple as you think)
  205. LS1 driveshaft with LT1 slipyoke... is this a problem?
  206. T56 Rebuild
  207. Help chosing a gear.
  208. ? 3.73:1 traction probs ??
  209. 4L60E from LS1 and LT1 much different?
  210. How to remove brake mounting plates from 10-bolt?
  211. Need Transmission Advice.
  212. My ring and pinion broke
  213. Gear choice with a new strange 12 bolts
  214. Ram HD free reving on Freeway?
  215. I Need a GM P/U 4x4 3.42 rear end..
  216. LT4 pressure plate?
  217. Clutch decision?
  218. Strange 12 bolts without tcs,abs...
  219. Gap between converter and flexplate
  220. tranny help?
  221. Help with rear axle spline
  222. How tough is the T56?
  223. Removing stock U-joint?
  224. could the clutch be causing thrust bearing wear
  225. transmission
  226. Tremec trans?
  227. mild tranny vinrations
  228. SLP pressure plate
  229. Clutch Reservoir Empty, problem?
  230. Best short throw shifter for T56?
  231. Ebay rear end
  232. "Thud" when accelerating
  233. 12 bolt trq arm bolts...help
  234. T56 Bearings
  235. 2-3 upshift
  236. Need Opinion on Tranny Problem
  237. Ebay TORQUE CONVERTER's
  238. Driveshaft
  239. What Gears to Use?????
  240. Just makin sure
  241. T56 gear upgrades
  242. 150+ more HP = transmission or driveshaft failure?
  243. Clink in the rear (A4)
  244. Best place to get T-56?
  245. Question about rear ABS exciter ring
  246. Transmission whines in 3rd gear.
  247. Do i need a rebuild?
  248. 4l60e or 4l80e?
  249. Auto to manual
  250. Where can i get a pressure plate!
