How do I install trans cooler on 95 Camaro?
Old Jan 30, 2005 | 02:19 AM
96camaroz28lt4's Avatar
Can anyone find me some instructions or a how to to this installation? I need it ASAP wanna install it for a buddy THnx.
Old Jan 30, 2005 | 04:10 AM
Brent94Z's Avatar
Super Moderator
Re: How do I install trans cooler on 95 Camaro?
http://www.bfranker.badz28.com/94Z/trannycooler.htm
Old Jan 30, 2005 | 11:43 AM
Is this a simple install?
Old Jan 30, 2005 | 05:57 PM
camzaro28's Avatar
took me about a half hour! i would say it is pretty easy once u start goin. i procrastinated for a while, then once i got goin, it was cake!
Old Jan 30, 2005 | 06:23 PM
NastyTA's Avatar
Simple install, don't be scared. Basically what you're going to do is splice the cooler in line with the return line from the radiator. This will route the fluid through the radiator cooler first and then the auxilliary cooler.
Old Feb 2, 2005 | 05:53 PM
NBred94's Avatar
+1 to the rest, very simple install, and cheap insurance.
Old Feb 3, 2005 | 12:23 PM
gtzcamaro's Avatar
I put a Hayden on my 94Z the other day, I decided to mount it on the pass side for air flow so I removed the stupid little black piece that screws to the air dam and mounted it to the factory bolt locations and in about 30 minutes presto cheap tranny insurance I noticed even after hard driving and in town stop&go the tranny cooler is still cool enough to touch without getting burned, I say this is a very good mod I paid>$25+shipping off ebay for mine included everything I needed&fairly comprehensive instructions to boot
Old Feb 3, 2005 | 09:43 PM
Loadre's Avatar
Hardest part is figuring out the feed/return lines. Brent's page takes care of that though.
Old Feb 4, 2005 | 05:04 PM
gtzcamaro's Avatar
I don't know on manual since I have an A4 but the transmission feed line is on the bottom right hand side or pass side depending on how you look at it? And the return line is the top right hand side or pass side line it should be coming out right near your rad cap. Once again not sure on manual cars since I have an A4 but I'm pretty sure they would be the same. I just want to say this is a very easy/cheap mod well worth the money especially if you have high miles or are making more horsepower, from what I've read and been told by mechanics if you can lower the average operation temp by 20 degrees you can effectively double the tranny life
Old Feb 7, 2005 | 09:40 PM
RacingTiger04's Avatar
have any pics of that install location? im having a fun time trying to figure out some kind of bushings to mount it to the radiator with but i could find somethin simple if mine would screw in there too
hotrodyou1
Dec 20, 2014 10:05 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
