View Full Version : Drivetrain
- A4 with slicks come in here
- Tell me Ididnt break my rearend!!!
- Jolt forward in 1st
- Royal purple gear fluid. GM additive needed?
- heavy clutch pedal + chatter
- 4.10 gear install instructions?
- How can a new 2000 stall help me out performance wise, etc.?
- stall converters (rskrause please reply)
- Clutch holds well in 1st-3rd but slips in 4th-6th?
- transmission id
- One Tire Spinning!
- HELP!! Popping noise when I accelerate
- Aut. trans. temp gauge. - AutoMeter - Temp sensor - (TH700, year 1987)
- 99 T-56 reverse lock out?
- Billet flywheel
- LT1-TH350/400 People Inside Please
- Electronic Speedometer Help Needed
- Shifters????
- Good Place to Buy a Tranny Mount
- A4 vs M6
- GM 4L60 transmission or TCI streetfighter from Summit?
- mcleod street twin in ls1...daily driver.or kevlar/organic??
- Clutch or Cylinder?
- 4L60E shift points....???any one know?
- Hope for the 7.5 10bolt! 10.80's with it.
- Blew my driveshaft
- 95 4L60E Terminology + Questions
- what was left out on my rebuild?
- Transmission gurus, any ideas?
- Here's a new one.....noises..
- highway drivin
- 373 gear down-sides?
- will turbo 350 bolt up ls1
- Trand fluid change - a4 - should i?
- Where to order my moser 12 bolt from?
- Reverse gear slippling
- Broke trans mount--> and now
- What a T56 worth?
- Slight grinding on engaging most every gear.....possible problem?
- FINALLY...something on an LT1 that isn't expensive.
- Stock Shifter Fails to "Center" itself in N?
- A4 vibration in third gear
- New spec stage 3 clutch or use stock 1???
- What gears came in my 94 Z?
- Tranny Question
- B&M deep pan trans cooler
- A4 ---> T56 conversion. Anyone have detailed wiring instructions?
- pros and cons of lowering the lockup speed
- Quick question, what tranny oil do you recommend?
- car shaking!?
- 3000 stall problem
- B&M TRANSPACK, HELP 4l60e guys?
- Moser 12 Bolt, what will I need?
- This clutch is great ...... WHAPwhapwhapwhap.....WTF!!!
- t56
- GM 4.10 gears in 02 Z28
- Downshift.....no increase in rpms??
- 10 bolt questions????
- M28 trans with 3.42's or 3.23's?
- putting an old 9" or 12 bolt in....there has to be a way
- T-350 swap Q's Please help.
- Help tranny cable...
- 4l60E How fast is 2nd Gear?
- TH-400 Dipstick help
- ( 4L60e ) When you put the shifter in D .....
- T-56 Viper rebuild?
- Ticking Noise comming from Rear End!!
- Chang of heart, TH 400 is coming! need advice/help
- Change of heart, the TH 400 is coming!! need advice/help
- Odd 4L60E problem , need help please
- What causes a rear end to scream?
- Code 82 Trans 1-2 shift solenoid
- T-56 rebuild kit
- putting a 99t56 in a 93
- car pops out of gear
- How to switch entire ABS system from non TCS too TCS
- 3.73 gear swap with series 2 carrier
- tranny prob/and question..please help
- t-56 help asap!!!!!!!!!!
- slave cylinder ?
- t56 leaking
- Tranny Pan leaking!
- swap to spec stg. III or keep custom clutch?
- Need a professional!!!!! 4L60E
- Gear Ratio
- stroker w/ stock clutch???
- Re-Installation of Rebuilt 4L60E?
- Automatic downshifting with 3.73's
- spec clutch stage 2 vs. stage 3
- rear pinion angle question
- where to buy a t56 conversion kit??
- How lucky have you 10-bolt fans been?
- Help with 4L60E shifting problem
- Bearing/gears/posi???!?!??!
- incrediBle mod foR Autos!! (freeeee)
- Gears in 97 vert
- They making a 9" for ABS only cars yet??
- differences between mcleod master cylinder and a 2001 GM master cylinder
- Need m6 vin for 96 Z
- Best T56 casting number??
- how hard to change rear end gears?
- Clutch noise
- Driveshaft length for a Moser 9"
- Can i make a rear with TCS work on my non-TCS car?
- transgo auto shift control
- Tranny Swap? Time?
- Richmond Gear 3.42 Part Number?
- 97 Torque converter different?
- Need help on what spline axels to use? (nine inch)
- Worn out posi? How can I fix it?
- Eaton Posis Back Ordered
- Spec IV with the stock 10bolt?
- TC - differnece between engage and locked?
- good buy or not
- torque converter???
- 14-bolt option?
- will this axle work on my car...need help fast.
- clutch install guide?
- T56-4l60E wiring harness the same
- spec clutch
- A4 guys ...whats your trans temp?
- Torque Arm Comparison?
- Good trans shop in Michigan
- Picture of Tranny Mount
- install costs
- Tranny question
- when downshifting to 2nd gear, does not want to stay in gear
- I hould have known!! Need some clutch help!
- Lowest ratio with spool in Moser 12-bolt?
- gear question
- E bay tranmissions
- Install and uninstall of T56?
- Swap Tranny or fix it?
- Holding a gear in auto/ highwayRPM question??
- Reverse Syncro???
- need some help ASAP - anyone know a part # for stock transmission cooler lines??
- Online walkthrough in removing a '95 4L60E?
- 3:73 gears for my camaro????
- Reverse Syncro
- Slot Car Racing parts?
- T-56 Reinstalled...BIG PROBLEM!
- Detroit locker in a 9"
- grinding on downshift to 2nd...
- Help With Axles!
- Rear end being rebuilt, Have a few questions...
- 6-speed problems
- any clutch recomendations?
- 99 Formula with Overdrive...?
- 3200 stall too much for hotcam?
- Hydrolic issues with LT1 clutch
- How streetable is a SPEC Stage III?
- is htere any additives that can help 4l60e from breaking down
- Moser 9" housing?
- transmission problem
- 1993 trans ? (not being electronic)
- Pinion bearing question?
- rear end swap
- rear end swap
- why are the LS1 clutch pedal easier to push than LT1
- 3200 tc and 3.73's
- Tranmission Swap - Help!
- Gear Oil Thoughts
- tranny fluid leaking out of bottom fitting on case - what to do
- rear end noise
- Anyone every ordered from Drivetrain Specialists??
- is this normal
- Spec or Center Force ???
- Need Help! Turbo 350 Questions
- Neal Stall Convertors? Good/bad??
- Tranny Torque arm mount part number?
- wheel bearings
- tranny sensor and gauge
- shift linkage shot?
- T56 conversion....parts....
- Rear end noise
- Will M6 LS1's burn their clutch up easy by powershifting?
- cluthes
- Grinding after converter install
- Whining rear end
- Major street twin problem please help.....
- T/A rearend cover, worth it?
- what size threads are the torque converter bolts on a 700r4?
- Where to get gears from? 3:73 for series 2 carriers?
- What is/causes clutch chatter?
- help: clutch adjustment(new centerforce)
- Replace flywheel durring clutch install?
- will a 96 m6 rear work in my 97 A4?
- Auburn Posi Questions
- axle question
- WTF No TSB for '97 Driveshaft!
- Website for clutch install??
- stock clutch on LS1??
- way to determine stall on converter?
- flywheel ?
- Stall Converter
- Leaking TH 350
- 4.11 gear ?
- should I use loctite on the tranny bellhousing bolts? also what is the torque spec?
- power of the plate
- Tranny problem with my 97 blazer...
- tranny knock
- Too much tranny fluid????
- Anyone not happy with their Spec IV?
- Pro Built Automatics?
- horrible grinding noise
- What is Torque Management
- auto downshifting questions..
- M6 Tranny Question
- Can I save my Converter?
- Do I NEED a transmission jack to remove my 4L60E?
- Please HELP!!! Rearend Install Question ??
- Where to find three series carrier?
- Lt4 Clutch
- Difference in Rearend from LT1 to LS1
- which gear oil?
- diff carriers
- tc lockup - tunercat... unlocked , locked ?? what does it mean?
- How many quarts + Ring & pinion question
- What Size Stall?
- Need help with transmission problem
- stupid oil question
- tranny slips shifting to 2nd
- Normal 2001 A4 Shifting?
- Help 95 no 3-4 upshift
- Chromoly, Steel, Aluminum Driveshafts??
- Burnt/Blown tranny?
- Towing question
- Good Set-up?
- Very bad Vibrations
- Street Twin question
- Z95M6 sent you pm
- Driveshaft length
- Tranny question in my 96 z28.
- 12 Bolt questions, Moser or Strange?
- Helpful tip for clutch install
- my rear is crooked...
- ID this sound please!
- Pinion Install ?
- TH-400 into LT1 car swap
- Beefing up 10-bolt
- leaky pinion seal & gear change
- Need Ls1 Transmission Mount part number
- Revised T56 Slave/Master Cylinder.
- when do i need an adjustable slave cylinder
- Can a sturdy 10 bolt be built?
- Trying to Verify gear ratio on a LS1
- STUCK!!Having trouble after street twin install
- Tranny Problems
- I have a question about my moser with 4.10s?
