View Full Version : Drivetrain
- Shifter linkage will not hook up
- Any information on building an 8.8 rear for 4th Gen?
- Replacing a clutch this weekend
- 700R only starts in reverse
- lt1 t56 shiftrail binding
- rear end questions
- Clutch issue,, please give advice
- Slave Cylinder R&R for dummies?
- 2.73 Gears
- ls1 t56 camaro tail housing
- Cryo-treated gears?
- Coverter selectio--see mods in sig
- 1996 V-6 5 Speed problems
- hooking up a trans cooler
- which trans mount?
- Can you figure my vibration??
- 3.73 problem
- shift kit question..
- tranny dipstic tube
- Can't pop the driveshaft out. >.<
- transmission problem?
- Using Gears from a 1980 Trans Am
- Dragging the anchor
- Neutral Safety Switch Issue
- Just installed my Moser 12 bolt - Here's my thoughts...
- LT1 Slave Cylinder Questions
- FLP & D&D
- Looking for a converter, can't find what I need
- Stall ratio question...
- clunking from rear
- Clutch Master and Slave Help!!!
- What did I blow up in my built 4L60E
- Transmission tailshaft housing gasket?
- T56 Poly Trans mount? Anyone have one installed?
- Help!!! Clutch Master Cylinder Installation
- Divability with Aluminum Flywheel
- Hanging in 1st and 2nd way to long
- I think the Pro 5.0 shifter jegs sent me is the wrong kind ??? Help ?
- A4 400RWHP - Going From A 3:23 To A ???? Rear Gear
- Good place to buy tranny mount??
- Shifter movement-T-56 on LT1
- Difference in M6 & A4 center section?
- 4l60e rebuild
- 4.10 whine, need help
- fabricators and engineers inside
- T56 running hot???
- T56 input shaft/ 4th gear
- shift kit
- Biggest tranny cooler possible?
- Mcleod Street Twin
- Bad whine and Bigger than 4.11's?
- kragen clutch in a cammed car
- ratchet shifter?
- Panhard Bar???
- leak rear end
- just tested my Clutchnet clutch.
- Spec IV extreme outter disk ware and funky flywheel "burn"
- Will stock LT1 flexplate work with a TH350/400?
- programmer or shift kit?
- wheel hopp???
- Spohn Driveshaft???
- Tranny swap
- Gears?
- T5 Swap Question
- New Transmission
- 1 quick question.
- clutch install tips
- Street twin real spongy after motor rebuild
- Need bolt sizes for TH400 swap (did a search)
- Leak at slave cylinder
- Trans was whining, now slipping......???
- need help with th350 conversion
- Trouble shifting into reverse
- 93 gear swap speedo question
- Ring Gear/Reluctor Ring Question...
- Reduce Line PRessure on 700R4? Reduce hard shifts?
- How much for a 700R4 Rebuild?
- Best price on SPEC stage 4 for LT1?
- 4L60E Shift Knob Question
- Tranny mount: Spohn Vs. LS1
- Gears
- Level10 - Mysterious Trans.Co.?
- should i be worried? tranny dipstick clear?
- Where to get a 12 bolt rear and pricing..
- Transmission Mount?
- Anyone using B&M Torkmaster conv.?
- Engine/Trany mount
- Transmission Vibration - time for a new mount?
- shift kit suggestions?
- gear ratio for a Ford 9" ?
- need ideas ?????
- Spec Stage 4 Clutch Traffic?
- mcleod clutch problems
- 2002 A4 w/2.73, Have Questions
- Slipping Clutch Question
- 95 Z28 - 3rd 4L60-E, anybody help?
- what should i shift at?
- 700R4 shift point change question?
- Missing bolt in differential...
- 12-bolt rear end
- clutch hydrolics questions
- 4th Gen A4 help
- clutch break in question (spec)
- Which carrier do i have?
- I need help
- Rear wheel bearing change?
- Weird problem - Clutch
- heat problem.. help?
- Broke an axle or the gears
- I need a new clutch
- Tranny help???
- remove dust cover??? (3.8/4l60e)
- rear end swap
- Just snapped my driveshaft!! (But now car won't roll)
- clutch
- Anyway to force the A4 into Limp-mode 3rd gear only?
- Shifter shakes in 3rd gear
- New clutch, won't go into R, burn it to the axles?
- MAC rearend cover
- What tq needed for scatter shield?
- gears
- When my car (with a Street Twin) sits for very long the clutch sticks. Why?
- 6 Speed Conversion
- Rattle in shifter
- grinding from transmission or rear end??
- Help!! My A4 wont move in any gear(After motor rebuild)!!
- TCI Streetfighter 3000?
- van 4l60e vs z28 4l60e
- 2.73 to 3.73 - Gears
- MOSER 9" OR MOSER 12 BOLT
- 700R4(4l60) in comparison to 4l60E
- Stall rpm's in high altitude?
- pics from my spec 3 install
- Camaro rear end in S-10
- Problems with clutch after motor install....
- 1999 4l60e in a 1995 z28
- Is there any way of decreasing gear whine??
- Play in Trans output shaft.
- something in rear leaking
- revs up while shifting into o/d
- Questions about stall and highway cruising.
- '02 Hurst effort?
- Best LT1 Daily Driver Clutch
- Those in Chicago suburbs w/ stall converter.....
- Clutch Bleeding
- Need M6 Help !!!!!!!!!
- Need M6 Help ASAP!!!!
- I want to go faster but my car doesn't want to
- Anyone out there put an aftermarket shifter on their 4th gen auto?
- 91 700R4 in a 94 Z?
- 700R4 lock-up
- Help 02 Z28 Tran Problem
- Signs of a bad tranny mount?
- if installing a stall conv. should i beef it up?
- 96 T56
- lt1 and ls1 axles same length?
- torque converter failing??
- Stall converter questions
- race rebuild kits 4l60e
- Steet Twin slipping
- Driveshaft And Safety Loop???
- gear whine only in 6th gear
- Where to find a good rebuilt or new transmission (T56) on the net?
- b&m shifter...is it a ripper?
- Is a new Flywheel NEEDED?
- Mcleod Street Twin GP
- Axle Option
- Do deep transmission pans reduce ground clearance?
- Shipping transmission by UPS. Problems...
- 700R4/4L06? Strong Trans?
- Buying TA rearend girdle, do I need the main cap stud kit?
- 4l60e
- 3.73 a4 install need to flash pcm or will work
- Prob after DTS 12-bolt install
- busted hydraulic hose from master to slave
- Damn Spec!
- Trans Stall Stock/shift Rpm.
- help from others with a 9inch
- Tips on installing stock Torque Arm
- Ring Gear Diameter
- MY gears
- Possible gears....
- car vibrations
- Question about tranny mounts..
- Funny tranny noise
- Street Twin installed = Holy crap!! Got some ??
- Weird 4L60E problem
- Gear Swap
- Tranny Mount Replacement Help!
- Never take you car ro any ACTION TRANSMISSION
- changing shift points?
- Are my reasons true? about slave cylinder's
- 4 channel rear
- I BENT my PANHARD ROD
- tranny fluid for T5
- Spec stage 2
- Eaton Diff
- ABS ring gear In Rear
- is the TC interchangable between...
- Swap 4l60 with 4l60E
- Shifter linkage mystery cable.
- What type of diff. and axle's come stock?
- Tranny mount help.
- turning issuse
- vibration at 80
- Redoing Gears At This Instant. Help!!!
- The 10 bolt in its final hour - PICS
- what parts should I buy for trans
- Rear Sway Bar - Aftermarket Rear end
- Weird Ticking noise .....
- Having to manually shift my A4
- 4L60E problems
- Clutch won't disengage all the way?????????
- Help ID my gears..
- Permanent torque converter damage?
- Tranny mount options? Can't stand the vibrations!
- Changing torque converter..
- Loud clunk underneath car
- Possibly a clutch problem?
- Looking for a certain kind of lug nut......
- 700R4 in f-body swap?
- Clutch to get: McCloud or SPEC
- LS1 Driveshaft = amazing
- 3.90 gears on a 12-bolt. Good choice?
- 4l60 slipping in 3rd and overdrive, help please!!!
- Rear gear ratio?
- Built 4L60e - in 3 weeks
- steel transmission mount??
- Why very hard to push the shifter knob?
- V6 Auto-Man.
- Take foot off Gas Loud Rubbing/Grinding Sound
- Skip Shift Selenoid
- Automatic Transmission Service
- AH!!!!!! Tranny mount ?
- speed...times
- Push in clutch hear grinding noise
- Shifter Question
- 4L60E or 4L80E?
- Hays clutch???
- Getting 1st Gear
- best way to set up trans shift kit?
- Rear axle play
- Torn Transmission Mount + Stripped Bolt Hole. HELP
- Clunking Woes
- what gears
- Time for a new transmission
- Tran's mount don't mount right.
- Bent T56 output shaft, need help!!!!!
- what carrier do i have with 2.73 lsd rear?
- Torque converter problems, please help!!!
